What is needed with a BX22
   / What is needed with a BX22 #1
Anonymous Poster
Epic Contributor
I am close to buying a BX22 for mowing, maintaining my gravel driveway, snow removal, and light loader work. I am planning on the BX22 with loader and hoe, back blade, 4 position valve on front, grill guard, 60"MMM, and turf tires. Also tooth bar and hooks for the loader, a hook on the hoe. Am I missing anything i'll regret? How about remotes on the back? Is a block heater needed? Thanks for the help.
   / What is needed with a BX22 #2
In your location, a block heater would be a great idea unless you are able to keep the tractor inside during the winter. It sounds you have thought of most other things.
   / What is needed with a BX22 #3
you may have traction problems in some situations with the turf tires. they tend to load up and act like slicks in muddy dirt and snow. I purchased mine with the r4 bar tires, this was the right choice for me.
   / What is needed with a BX22 #4
Ditto on the block heater and bar tires.
Don't forget to buy a set of filters (fuel, oil, hydro) and the appropriate oils to keep on hand. You'll need them to do the 50 hour service and they're good to keep in case you damage a filter, etc. Make sure you have a good grease gun and high pressure grease too.
Gregg
   / What is needed with a BX22 #5
Larger alternator if you plan to add lights, which you will and if you ever add cab?. Also service manual is a good thing, extra blades for the deck, loaded tires?
Good luck.
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
