What is it
/ What is it #1
AMP762
s.c.
Mitsu D1550 Farmall super A
Could this be your brain without diesel fumes /forums/images/graemlins/confused.gif
/ What is it #2
Proper name is hedgeapple, but called horse apples around here. Happen upon this <font color="blue"> web site </font> some time ago. Who would have thought you could sell these things. /forums/images/graemlins/confused.gif I have hundreds on them laying on the ground rotting away.
/ What is it #3
</font><font color="blue" class="small">( Proper name is hedgeapple, but called horse apples around here )</font>
I grew up in southern Oklahoma, where they were also called horse apples, but I thought the proper name was bois d'arc. And when I was little kid, I thought I knew why they were called horse apples, because my first horse loved'em; ate'em like candy. We didn't have any in our pasture, so I'd go get them from the adjoining neighbor's pasture for him. And then later, I had two other horses, and I never saw a horse that would touch one except that first old horse.
/ What is it #4
Horse apple! Otherwise known as bodarc
/ What is it #5
Wow!!
I'm sitting on a fortune.
One mans trash is another mans treasure.
Solo
/ What is it #6
I've always known them as Osage Oranges. The wood of the tree is bright yellow and very rot resistant. Commonly used for fenceposts (the wood not the fruit) /forums/images/graemlins/smile.gif
/ What is it #7
I've seen the logs used for house piers. The wood is murder to cut with a chainsaw.
/ What is it #8
OK. Here is another <font color="blue"> web site </font> on the Osage Orange tree. Read down in it to find the origin of Bois D'Arc.
Lots of fences have been built with Bois D'Arc fence posts. A Bois D'Arc fence post will last an awfully long time.
/ What is it #9
</font><font color="blue" class="small">( A Bois D'Arc fence post will last an awfully long time )</font>
Yep, when I was a kid, there weren't enough of the to do all the fence building, so you used those for your corner posts.
/ What is it #10
Used to have dodgeball / horse apple fights when I was a kid. They DO hurt.
Many years ago, quite a few old homes were built on top of bois d'arc posts. Pronounced BOdark.
/ What is it #11
Native Americans chose to make their bows from them. At least the ones in the midwest did. I don't know how far south they grew. /forums/images/graemlins/cool.gif
/ What is it #12
They extend into at least north Texas. I have a lot of them on my land. In fact, my south property line is bounded by Bois D'Arc Creek. /forums/images/graemlins/grin.gif They are a real nuisance. A large tree in a good year can put off a hundred or more fruit. They are messy when they start to rot. And the branches have lots of thorn on them. /forums/images/graemlins/frown.gif
One of my hunting buddies got into making long bows. He made one using Osage Orange wood. Took a looong time to carve that one out.
/ What is it #13
Since I became aware of them I have been finding them here in Brazos county along stream beds. I have found them close but not on my property. What I have now was part of my grandparents 200 acre cotton land so it was all clear at one time.
Vernon
/ What is it #14
Ever wonder has fast you can dull a chain saw. Find a dead and well cured Bois D'Arc tree. /forums/images/graemlins/grin.gif Caution: do not try this in dry conditions. The sparks from your chain might start a fire. /forums/images/graemlins/smirk.gif
/ What is it #15
I bought a piece of property where someone had logged a bit 20 or so years ago. There was an Osage Orange or what we also call "Hedge" that had been cut down. The log is about 20" dia and about 5' long. That thing has to weigh over 400lbs. You can see where someone had started to cut it with a chainsaw, got about half way through and thought better of it. I just dug the stump out the other day. The feeder roots were not an issue, but the tap root tapered from about 18" dia. to about 3" over a length of about 4'. If that thing had not been on a small hill that I was leveling out, I would probably still be digging to get that out.
That stuff makes good fire wood with two exceptions, it's very difficult to cut and nearly impossible to split. A friend of mine has a log splitter made from the boom cylinder of a JD410 (I think) backhoe with a huge wedge on the other end, mounted on a 10" piece of I-beam. I have seen this thing nearly push the wedge off with a large piece of hedge in there. But...it does burn for a long time and burns really hot. It's good fire wood if you can get it. Cut it green, split it right away then let it sit for a while. It's also fairly impervious to rot and insects.
/ What is it #16
Double Ditto on the firewood. I once had a good source of it supplied to me for a couple winters as someone cleared a creek bottom. The stuff burned so intensly hotter than any other hardwood that we had to be careful not to overfire the stove. I had no way of measuring it objectively, but it definitely put out more heat than other wood.
/ What is it #17
<font color="blue"> That stuff makes good fire wood with two exceptions </font>
Is there a third exception? I had always heard that the wood was not good for burning in a regular fireplace as it popped a lot and threw sparks and embers. OK for a closed stove or furnace. Since I have a regular fireplace, I have always pushed it into a burn pile and burned it. Have I been wasting perferctly good firewood? /forums/images/graemlins/confused.gif
/ What is it #18
BB TX, you are right. I had some old fence posts I burned last winter. It did get hot but cracked and popped like crazy and if the burning log was moved the least bit it sounded like rice crispys and looked like the 4th of July. I would not want to put it in an open fireplace. Probably would work fine in a closed wood stove or furnace.
/ What is it #19
</font><font color="blue" class="small">( They extend into at least north Texas. )</font>
They extend into North Alabama also.
/ What is it #20
I just closed escrow yesterday on 15 acres in Bastrop, TX near Austin. We have at least one of these trees on the property. I could see the fruit from the street and wondered what it was. Thanks again to this group for the education. I won't get an up close look until Sunday when we finally get to move in though.
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2023 New Holland C327 Compact Track Loader Skid Steer (A61567)
2023 New Holland...
UNUSED INDUSTRIAS AMERICA HI-1100T TILT LAND LEVEL (A62130)
UNUSED INDUSTRIAS...
UNUSED RAYTREE RPRB72-72" HYD POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
30 GALLON AIR TANK W/HOSE (A62131)
30 GALLON AIR TANK...
