What is it with Harley riders?
   / What is it with Harley riders? #341
I'm not a trucker and am ignorant in the subject, so I ask to be educated. How is it that a location can ban the use of the compression brake? Is it, as a brake, a safety feature? How do you tell the driver to not use his extra braking abilities?
I hear things like this, and I think, would it be better to be annoyed by noise or to have a truck strike the house at the bottom of a hill in a quiet zone?
Every time I've heard of these policies being initiated it's always put forth by some ******* low-level politician or local businessman with an inflated sense of self-importance. They're tired of having their comfort interrupted and have the clout to get these signs and policies put in. They're probably just creating quiet zones in-between trips shuttering local shooting ranges, and purchasing beachfront property in other states, closing those beaches previously open to the public.
Is that last one a little specific? Well there are 3 cases of previously public beaches being shut down by out-of-state members of the female anatomy in Maine at this moment.
purely noise control, within city limit no jig brake... Jig brake doesn't work as good as service brake (brake pedal) but it is way cheaper (every axel on the truck and trailer has its brakes)... so instead of using the service brake the whole way to stop they used the jig brake 3/4 of the way then the service brake the last bit... in case of emergency one would use the service brake even if they are allowed to use their jig brake.
   / What is it with Harley riders? #342
Many towns with busy roads running thru residential areas have brake retarder prohibitions, that's nothing new. I believe their usage is more related to economy (saving brake wear) than safety.
   / What is it with Harley riders? #343
Owner-operators have exhaust options just like we bike riders. Jake brakes are at their worst where/when they like to be heard, y'know so we'll know they're coming. If your exhaust is generally louder than most your jake will be too.
But don't take my word for it, ask a trucker like I did. (None here? ok. :))
   / What is it with Harley riders? #345
It never clicked that a modified exhaust would result in a louder exhaust brake; you'd think it would have, but nope.
Thanks for connecting the dots for me. 🤣
   / What is it with Harley riders? #346
Yes, straight pipes on a truck with a Jake brake will be louder, generally louder than the exhaust when under power.
The exception to the exhaust brake noise rule is the Blue Ox exhaust brake, which is an air operated gate valve the is attached to the outlet of the turbo. When operated, the gate closes and the exhaust is only allowed to exit through a small hole, about 1/2" in diameter it I remember correctly. When the Blue Ox is activated, only a hissing noise is heard, no popping noise like a Jake brake. I don't know if they are still in use, I installed a couple on a friends trucks back in the 80s.
Also, while on the subject, Jake brakes were originally designed to allow trucks to descend long grades without using their service brakes. They really got popular out west in the mountainous territory. Most I've seen had a switch that would allow you to use 2, 4, or all 6 cylinders if full retarding wasn't necessary. With all 6 cylinders enabled, they can provide around 300 hp of retarding power on most engines.
I bought my first truck, a basket case Peterbilt 352ST in 1972, and after 1976 had at least three trucks until I sold them in 2018. Wasn't sad to see them go either.
   / What is it with Harley riders? #347
Just a note on Trucks and brakes... Off topic , but......
On a recent motor trip out west, we were coming down out of the high country in S. Colorado.
On one particularly long and steep grade, we passed a rig pulled to the side. In passing, I noted that both front tires were burnt off, with attendant damage to the cab. Hot brakes were my first thought.
Jake brakes have an important role.
Truckers motto, "Use the same gear while descending a grade as you would going UP!"
   / What is it with Harley riders? #348
I have a F450 crew cab..Last month had 20K behind it traveling to upstate NY. Some long and steep downhills ..My truck has the engine brake and it is simply awesome for controlling the truck trailer combo. It makes it so that the only time you need to use the actual truck or trailer brakes is if you need to actually stop.
   / What is it with Harley riders? #349
I’m late to the party as usual, but there are two problems with jakes. First is the idjits who put straight pipes on, the second is the idjits who use the jake because they like hearing the engine rather than to control their sped the way it was intended. Those are the guys you hear coming down a hill and every time it starts to quiet down they hit the throttle again.
I said that there are two problems yet if you look closely I only identified one… the idjit behind the wheel.
   / What is it with Harley riders? #350
Personally, I would rather hear a Harley any day than another of these 4-cylinder little cars gunning it with a loud muffler. I always have thought that 4-cylinder engines sound like they are straining. Not to say that there isn't a place for 4 cyl. cars, just not with a loud muffler.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
towable flood lights (A56857)
towable flood...
