What is it called?
/ What is it called? #1
jerrywa1234
Monroe, WA
John Deere/4200
I keep breaking the pin that holds my driveshaft to my finish mower. It is a 48" Yanmar. Does anyone have a thought as to why I might be snapping those pins? By the way, what are those pins called? I thought it was a drift pin but I am not sure that is correct.
Sure appreciate any thoughts.
Jerry
/ What is it called? #2
Jerry, Shear pin? roll pin...Usually a shear pin so it will break before damage occurs... But why is it doing it so often, Is the hole rounding out..?:confused:
/ What is it called? #3
The reason it may be breaking is because it is not being replaced with a shear pin but a normal bolt???? Just a thought here that is all.
murph
/ What is it called? #4
Are you easing the power take off in to gear or just slaming it home? Dropping the PTO at high RPM will break it almost every time.
/ What is it called? #5
jerrywa1234:
Welcome to TBN :D! What are you trying to mow :eek:? Jay
2019 JOHN DEERE 30G EXCAVATOR (A65056)
2019 JOHN DEERE...
2024 KUBOTA SVL97-2 SKID STEER (A65056)
2024 KUBOTA...
1997 LEDWELL 48FT DOVETAIL TRAILER (A67714)
1997 LEDWELL 48FT...
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
X (A68191)
X (A68191)
