What is it called?
/ What is it called? #1
jerrywa1234
Monroe, WA
John Deere/4200
I keep breaking the pin that holds my driveshaft to my finish mower. It is a 48" Yanmar. Does anyone have a thought as to why I might be snapping those pins? By the way, what are those pins called? I thought it was a drift pin but I am not sure that is correct.
Sure appreciate any thoughts.
Jerry
/ What is it called? #2
Jerry, Shear pin? roll pin...Usually a shear pin so it will break before damage occurs... But why is it doing it so often, Is the hole rounding out..?:confused:
/ What is it called? #3
The reason it may be breaking is because it is not being replaced with a shear pin but a normal bolt???? Just a thought here that is all.
murph
/ What is it called? #4
Are you easing the power take off in to gear or just slaming it home? Dropping the PTO at high RPM will break it almost every time.
/ What is it called? #5
jerrywa1234:
Welcome to TBN :D! What are you trying to mow :eek:? Jay
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A67148)
2019 RAM 5500 4X4...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
