What is it called
/ What is it called #1
bhammer
2017 mihindra 2538
Before I head over to the store, I thought I better know what the part is called.
I am looking for a stop block that I can mount on the metal surround by the height adjustment lever for the 3 point. When I have my mower deck on, there are times that I need to raise it to clear elevation changes or during tight turns to keep the deck frame from digging in. It would be so nice to have a stop block that I can set at the lower height setting and just push it to the stop.
Does such a thangymaboper exist?
/ What is it called #2
A bolt with a knob on it, washers top and bottom, tack weld a nut on a washer with edges turned up into the slot lever moves in.
/ What is it called #4
Maybe a sliding window lock would work.
If you need larger or stronger, maybe use a beam clamp.
beam clamp at DuckDuckGo
Bruce
/ What is it called
Thanks, that gives me ideas and a direction to go.
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
1996 John Deere 8400 Tractor (A66285)
1996 John Deere...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
