What is a tire, wheel, rim?
   / What is a tire, wheel, rim? #23
And what about water pump pliers? Channel lock pliers.
Johnson bar/breaker bar/strong arm and the list goes on and on and the proper NORTH AMERICAN spelling for a tire is tire
That's what I said Mate, "And then I throw a spanner into your NA works and spell it tyre."
   / What is a tire, wheel, rim? #24
My tires are tired of being tires because its very tiring being a tire.
   / What is a tire, wheel, rim? #25
It may not be correct but I tend to think of a tire as the rubber part, a rim as the metal part and a wheel as the entire assembly .....
Now, as far as some of the other things mentioned in this thread:
I always understood a Monkey Wrench to be like a pipe wrench but without teeth. It is for turning fittings and/or things with heads. A pipe wrench is for turning/holding pipe, therefore it needs teeth to bite into the pipe. A pipe wrench can cause unwanted damage to brass fittings
Now, as to a "left-handed" one ... well, that is entirely another subject
   / What is a tire, wheel, rim? #26
   / What is a tire, wheel, rim? #27
It is a good thing I understand Brit to a certain extent. I also can usually understand other peoples misspelling.
   / What is a tire, wheel, rim? #28
Bikes need help to stand up because they are two tired.
   / What is a tire, wheel, rim? #30
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
Toro Mower (A50324)
Toro Mower (A50324)
2019 TIGERCAT 234B TANDEM AXLE DE LIMBER (A54607)
2019 TIGERCAT 234B...
