What is a tire, wheel, rim?
   / What is a tire, wheel, rim? #23
And what about water pump pliers? Channel lock pliers.
Johnson bar/breaker bar/strong arm and the list goes on and on and the proper NORTH AMERICAN spelling for a tire is tire
That's what I said Mate, "And then I throw a spanner into your NA works and spell it tyre."
   / What is a tire, wheel, rim? #24
My tires are tired of being tires because its very tiring being a tire.
   / What is a tire, wheel, rim? #25
It may not be correct but I tend to think of a tire as the rubber part, a rim as the metal part and a wheel as the entire assembly .....
Now, as far as some of the other things mentioned in this thread:
I always understood a Monkey Wrench to be like a pipe wrench but without teeth. It is for turning fittings and/or things with heads. A pipe wrench is for turning/holding pipe, therefore it needs teeth to bite into the pipe. A pipe wrench can cause unwanted damage to brass fittings
Now, as to a "left-handed" one ... well, that is entirely another subject
   / What is a tire, wheel, rim? #26
   / What is a tire, wheel, rim? #27
It is a good thing I understand Brit to a certain extent. I also can usually understand other peoples misspelling.
   / What is a tire, wheel, rim? #28
Bikes need help to stand up because they are two tired.
   / What is a tire, wheel, rim? #30
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
