What is a shuttle shift?
/ What is a shuttle shift? #1
ragkar
Platinum Member
eastern PA-lower Poconos
JD2320 w/R4 $21,100 w/7.16%off
Yesterday I went to my local auto supply to buy some hydraulic oil for my Case 580K tractor. The guy said that there are many different oils and do I have a shuttle shift?
When I told him that my tractor has a lever on the steering column with three positions forward-neutral-reverse and no clutch he proclaimed that I had shuttle shift.
The oil that I got was Wolf's Head tractor oil type HT.
So what's shuttle shift?
/ What is a shuttle shift? #2
Basically the same way of shifting as in an automatic transmission (no torque converter though)....F-N-R...as D-N-R on a car....No gears are moved when shifting...lever operates a hydraulic valve, that directs oil to "cylinders" that lock "clutch-packs" into gear...the rest of shifting 1st-2nd-3rd gear etc can be designed in different ways...foot clutch and stick gear, gear selector, etc
These clutches are made of a bronze like metal, and are wet in oil, thats why they need a certain oil quality.....
Thanks AKKAMAAN That explains the how and why very nicely.
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
3-Pt Hydraulic Tree Spade (A66285)
3-Pt Hydraulic...
2023 JOHN DEERE 333G SKID STEER (A64277)
2023 JOHN DEERE...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
3ft Teakwood Totem Pole (A65583)
3ft Teakwood Totem...
