What is a leveling box?
/ What is a leveling box? #1
EdwardL
Emax 20
I've seen ads for a leveling box assembly. Can someone tell me what the purpose is?
/ What is a leveling box? #2
A tool used to level the mix and volume of production by distributing kanban within a facility at fixed intervals. Also called a leveling box.
willy
/ What is a leveling box? #4
It is used for the "adjustable" side of the 3 point lift arm linkage. This allows you to tilt an implement.
Thanks LS Tractor, I didn't know what that was and didn't understand Willy's description either. Now I realize it's a "manual" hydraulic link. Good to know, although I'll never need one.
/ What is a leveling box? #5
It also helps when you are trying to connect an implement to the 3 pt. system.
/ What is a leveling box? #6
It's a lot better than the damnable turnbuckles the machines tend to come with, and cheaper than a hydraulic tilt.
/ What is a leveling box? #7
This is the most refined form of the original on a 1951 Ford 8n. It was first invented by Harry Ferguson and offered to the public, in partnership with Henry Ford on the Ford model 9n, in 1939:
/ What is a leveling box? #8
For many years, ag tractors like our old JD had hand-crank box levelers on both 3pt lift arms.
The lift arms were telescoping with automatic latching. Implement side sway was limited by adjustable blocks rather than chains. Zerks on everything.
That combo made the 3pt very easy to adjust and use.
/ What is a leveling box? #9
I have a 9N and a Yanmar YM2310. I have been looking at leveling boxes online so that I can buy one, or even two, for my Yanmar. So far though all the ones I have seen don't have dimensions listed just what model tractor they are made for. Darn it.
Eric
/ What is a leveling box? #10
Our IH tractors (464's, 574) from the 70's and 80's came with one on the right side. Good for plowing that first pass or tilting a rear blade to start a ditch was all we used them for.
/ What is a leveling box? #11
etpm why don't you order one that will extend out about
4 or 5 inchs from what you have on your tractor you should be able to rig up something to hold the top in place
willy
/ What is a leveling box? #12
whats the word "box" have to do with this adjustable left arm for three point lift
/ What is a leveling box? #13
Who the hell knows, lol; it's probably the technical name for it put out when the initial design was patented.
/ What is a leveling box? #14
My Kubota M6040 has a leveling box on the right lower arm. Used mainly to assist in connection of Cat 2 implements. Also to angle or level land engagement implements that do not have this feature built in.
/ What is a leveling box? #15
Maybe a sales pitch like a lot of other crap in sales slogans
willy
2015 CATERPILLAR 525D DUAL ARCH GRAPPLE SKIDDER (A65056)
2015 CATERPILLAR...
2011 BRENNER TANK 200BBL CRUDE TANKER (A67714)
2011 BRENNER TANK...
Unused 2023 Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
Unused 2023 Del...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A66736)
2017 Ford F-550...
2014 FREIGHTLINER CASCADIA TRI -AXLE (A67714)
2014 FREIGHTLINER...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
