/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,951
I went back down after it calmed down a bit ...
And pushed the edges in ...
Then weet back up to the house and had breakfast ... !
Hour and a half later ... This is all that's left, I needed to get going, so I left it ... Now just outside of Chicago.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,952
Went out back and checked out my creek enlargement project, looking good, set a couple of raccoon traps while down there ...
I had hung a bunting off my back deck, and the wind would pick it up over the gutter and onto the roof ... It ended up pulling the gutters apart ... So I decided to fix it today, but ... My 32' ladder is out in the corner of the barn, and I'd need to get my trailer out to get it out, but first I'd need to get the tiller and land plane off the trailer ... So I came up with another way ... 4" step under the bucket, but enough I can still climb it, used the stabilizers to level the bucket side to side and set the 16' ladder in it ...
Then I loaded up a few traps to take out front ...
What is a “bunting” ?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,954
Daigle, does your blower use a linear actuator like the MF (RAD Technologies) front-mount blower?
If so: Take a 10"-12" or so piece of bicycle inner tube, glue it together at the top and stretch it over the top of the actuator. Make small holes for the upper mounting bolt to pass through.
This will prevent water intrusion. a problem I had almost every year until I tried this -- a suggestion from another forum member. Have not had to take it apart and dry & re-grease it since.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,955
Good idea, yes it does use a linear actuator. The problem I had was with the chute rotation dc motor. Water was coming in from the broken sheath protecting the wires. I have since repaired this and siliconed the entry point in to the motor housing.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,956
Ah. Different problem.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,957
Got home this morning, popped the BH off, and the bucket, switching to forks as I needed to get back to watering regiment ...
I wanted to add an extension onto the suction hose to my pump, and have a way to weight it down, so I had found some metal pegs/stakes one day while out and about for a walk while on the road, I figured I could heat them up and bend them around a 2" steel pipe, then put them on my 2" PVC extension ... I needed a adjustable height "bench" ... 😂
I used the torch on the first one, and didn't heat enough of an area, so once I started to bend it, it wasn't really round, I tried the second one without heat, and that worked OK! But I really needed to hang my weight on it!
Then I hooked up my water wagon and grabbed the tote for the front, and took the pump out back ...
Everything works much better, bigger pond now, and the straight piece of pipe that not only gets it out farther, it also has a rope to tie to the bank so it won't try to curl and get up to suck air ...
The pump will pump 158 gallons a minute, so when it starts the hose would really flop around when it was unsecured.
Got 350 gallons out today!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,958
After lunch I decided to tidy up the lawn some, mostly tired of dodging low tree branches when mowing ...
While I could reach most of them with the chainsaw, I used the pole saw pruner as it was quite windy out today, and that let me stay farther away from the chips flying!
Should give me enough room so I don't loose my hat! 🤠
And later I mowed the lawn, and yup 👍 it's much better now! 😁
Then I moved over to the fence between the lawn and the back pasture ... I left a few cedar trees in the fence line on purpose, eventually when I retire I'm going to have a couple of dogs, plus a flock of chickens, this fence line (once a finer mesh is added) will be the boundary between the two, and I figured the shade will be nice for both sides ... But I was tired of cedar needles getting down my shirt and pants!!! :oops::mad:
I got a full fork load and headed out back ...
When I built my ballast box I didn't really have a plan for the D-rings, but they came in handy for lashing down the pole saw, as it doesn't fit in the slots I made for the trimmer ...
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,959
I dumped that first load on top of the ashes from the brush fire I had on Sunday morning to start a new brush pile ... Then headed up to trim this cedar tree that I could fit under with my ROPS, but not my cabbed Kubota ...
Got a full fork load and headed down to dump it on the new pile ... Apparently there were still HOT coals ... And by the time I got down there an active FIRE! 🔥
Since Little Baby Fergie is red like a fire truck 🚒 she scooped up the pile and we spread it out on the grass ... As I really didn't want a brush fire today with all the wind ..
I was surprised it still burned, only really the cedar needles ... Once it calmed down ... We scooped it up and gave it a ride over to my new pond! 😄
And dropped them in!
And that put the end to that nonsense! Glad I had Little Baby Fergie to help me take care of that problem I inadvertently caused!
The cedar tree now looks like I should have room to mow under it with the Kubota! 😀
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #2,960
Yesterday was moving rocks and dead branches and small trees.
Will need to put the bucket on the finish moving the rocks to a new pile.
Moved a lot of rounds too while I was at it so I could split them later.
2019 TerraGator 7300 Spinner truck (A56436)
2019 TerraGator...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
2017 Nissan Altima Sedan (A56859)
2017 Nissan Altima...
2015 Ford F-350 Versalift Bucket Truck (A56858)
2015 Ford F-350...
