/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,301
yeah mud kicking my butt too. have to work road during those few days mud wind and sun all work together. so far sun starts to cooperate then goes away. cannot use box scraper, will not bleed off at all just clumps. got most of potholes fixed using grader blade and roller but really need to use box blade (no tines) to smooth little divets.
and of course rain and another 1/4 or so snow due friday night. makes it hard to maintain a road.
think I will give up for a few and tomorrow head up the road to change clogged fuel filter on MF1532 and get that fired up for first time since beginning of November.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,302
Moving snow on sunday was bad. The ground under the snow was muddy because it was so warm the week before. Put chunks of my lawn through the blower. The thing will chew through anything. I guess the next thing I'll actually be doing is replacing my divots and spreading grass seed.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,303
not good. filter changed, fuel going up into injection pump no issues pump bled out. still only sputters. suspect gel in injectors. not my tractor so dealer service call due.
meanwhile my GC2400 (just to keep on topic) runs fine and may tow the 1532 out of its park spot to allow access for mtx LOL
edit: now not positive pump bled out well so in day or so after battery charges will bleed it.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,304
Well, it was Thursday, but I hope I've used my blower for the last time this year -- we got a tad over an inch of fairly wet snow overnight and into Thursday AM. Hit it with the blower before temps rose too much; a few hrs later driveway was only wet. Dirt roads up here are horrible this year, and the .97" of precipitation we got out of that storm didn't help....
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,305
Working on removing two tree stumps with my GC1723 that are next to my driveway. It is going very, very slow. These roots and rocks are huge.
The driveway ice had been melting early this year and now is about 50% gone.
Today I'm going to remove the tire chains on the MF and swap out the studded snow tires on our truck.
Tomorrow I plan to swap out the weight box and MF Dozer Blade for the FEL and either the Back Hoe or the Box Blade.
Still have plenty of snow in the shaded areas as the temperature climbs to the low 50's during the day.
KC
B.T.W. I found these sheds about a month ago about 20' from the back deck. I normally find a few sheds each springtime on the property, but have only found a few matched pairs and never before found a matched pair this close together.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,307
WHISKEY TANGO FOXTROT??
Well, I knew it was supposed to get cold overnight (now +12F), but I didn't expect this! Glad I haven't yet removed the snow blower... and my camera apparently just died....
Here's a pic my daughter took with her phone and emailed to me -- sheesh!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,308
ug snowing here now and 22 deg. no expected accumulation but...when trying to fix 2 1200ft private roads the 2 70deg days 2 weeks ago and not being able to do anything since then due to rain/snow/hail/freezing rain/ (rain every day since, all 4 2 days ago and MANY snow flurries since then) since then screwing me.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,309
Wow, we received very little down by the big lake.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,310
It is just wrong that I had to be out at 5AM on the 28th of march moving snow drifts so that my wife could get out to work.
John Deere Gator 825i 4x4 Utility Cart (A50322)
John Deere Gator...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2019 John Deere...
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2015 ISUZU NPR 16FT BOX TRUCK (A52141)
2015 ISUZU NPR...
