What have you done to your Branson today?
   / What have you done to your Branson today? #1,761
Do you have a trail near or through your property? It's funny to see you rescuing so many of these and they're not even yours.
Yes we do have some trails here, plus the Police don't mind if you drive on the road.
The rescues are what happens when you dont take care of your toys + old gasoline.
Im trying to convince them to trade those dogs in on a new one!
   / What have you done to your Branson today? #1,762
Good luck! 🤣
My Technician found a source of my bucket drift. Months ago he isolated these cylinders and they proved fine. It just goes to show me that things are alright until they are not.
   / What have you done to your Branson today? #1,764
Tested my "new" implement the other day. It's a potato planter, but essentially does 3 things at the same time: Closes the last furrow, opens the next one and marks the ground for the next pass.
It does require some labor to put the potatoes in the furrow, but that's ok, we're not doing huge fields.
The test went somewhat ok, some minor tweaks need to be done but the soil, being clay and very wet, made these big clumps of clay which kinda defeats the purpose.
It really needs to be tested once the ground is a lot drier, almost like sand.
View attachment 2796593 View attachment 2796594
As you can see, not quite the result I was looking for.
This is a better example of what it should be doing:
The ground finally dried enough that we could finally plant the potatoes. We used this attachment and it actually worked awesome. A couple of adjustments on the first and second row, then it was smooth sailing and saved soooo much hand work.
The draft control was key to keep constant depth and made it so I didn't have to babysit the 3 pt lever. I just had to focus where I was going.
We did an area of about 300 sq ft. What would have taken us maybe 3 or 4 hours doing it by hand, turned into a 1 hour job and mostly taking our time.
Don't have any pictures though. We were trying to get it done before the rain sets in again.
   / What have you done to your Branson today? #1,765
Hit a milestone today on my Branson as I was moving some stumps and some dirt. 500 hours! Only 500 hours but lots of work done during that time. So far so good.
Fun fact: Just for the kicks, I timed the hour meter the other day. Every tenth is spot on 6 minutes to the exact second.
My mechanic replaced the seals in both my bucket cylinders. There’s a really neat DIY trick to install the cup seals on the piston located on YouTube.
   / What have you done to your Branson today? #1,767
this is so useful with small o-rings as well, never thought to try it with these bigger seals, definitely trying this the next time i have to repack a cylinder
   / What have you done to your Branson today? #1,769
Spent a half hour tilling up a raised bed from an old playground in my neighbors yard, and leveling it with the loader. Then gave it a final fluff to prepare it for seed. Float mode on the loader for the win! Also, auto throttle for the leveling work
   / What have you done to your Branson today? #1,770
First oil change!
Exactly 4.3l of Rotella T6. Maybe placebo, but the engine sounds quieter. It'll need another change in about 8 years 😂
Also topped off the coolant reservoir.
Hydro change at another time.
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
