What have you done to your Branson today?
   / What have you done to your Branson today? #721
Well, had a slight disagreement with the forks today with a touch of my own stupidity in between. :eek:
Now for the story. We took a couple eucalyptus trees down and I had a couple of logs on the forks. Decided to park the tractor, tilt the forks back a little bit and lower the loader to the ground.
Went to move some branches to the pile, came back to the tractor, didn't realize the front wheels were in an high spot on the ground, which means the loader was lower a bit more than usual. Proceed to fully tilt the forks back, then I lift the loader and found out that rail on the forks hit the winch quite hard.
The rail did hit one of the fittings, but being a swivel 90 degree fitting, it simply rotate out of the way without any damage whatsoever.
Good thing I didn't paint the attachment yet. :laughing:
   / What have you done to your Branson today? #722
View attachment 678564 View attachment 678565
Lol, could be worse. Maybe it will clear now that everything is bent properly.
   / What have you done to your Branson today? #723
I say it's a good thing your winch mounting was sturdier then the little headache rack on the forks.
But knowing the quality of work you do I expect that the repaired/replacement will be nicer anyway.
   / What have you done to your Branson today? #724
That headache rack was mostly a handle for when my dad is pruning trees or basically when we're doing sketchy stuff with the loader up high. Just having a place to grab onto, makes it much more comfortable to be up there.
I'll make it stronger, but not skid steer attachment strong though.
   / What have you done to your Branson today? #725
Well. you will just have to use your fabrication skills to make a repair that is much improved.
   / What have you done to your Branson today? #726
Have you considered getting an IBC tote and cut out an opening to step in (with safety chain added across the opening)? It can be fastened to the fork rack to keep it from accidentally sliding off.
   / What have you done to your Branson today? #727
Yes I have. I actually have 4 IBC totes that I could use. Two I kept ready for fire prevention if needed. The other two have a sticky goo inside that's a pain to remove. Some sort of vegetal oil or something, so I have considered cutting one of those and having it setup as a basket. I may do it at some point.
   / What have you done to your Branson today? #728
Even without the tank & just the cage there’s sticky goo?
   / What have you done to your Branson today? #729
It's just inside the tank. The cage is fine.
Turns out it's molasses that's mixed into cattle feed.
I'll do that at some point. I also have two other cages that I use for firewood.
2015 Cheverolet Tahoe SUV (A55853)
2015 Cheverolet...
1998 PTTT RUBBER-LINED WATER TANKER TRAILER (A57192)
1998 PTTT...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
JCB 215E SERIES 3 BACKHOE (A52707)
JCB 215E SERIES 3...
New Holland TC21D (A53317)
New Holland TC21D...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
