What have you done to your Branson today?
   / What have you done to your Branson today? #281
Got off work yesterday at 2. Spent an hour using the loader back-pulling snow. Works fabulous. Getting the hang of it pretty fast actually. Then I had to open up my driveway back to our pole building(which I haven't done all winter due to not having a reason/equipment to do). The snow was about 5 ft tall from the drifts and road-grader that does our gravel road. It was very hard(pretty much solid ice). Took a few times to get it chopped down, but did it with relative ease. I am really surprised at how sharply the tractor turns. Actually amazing how sharp it turns. Loving it so far! Only 2 hrs of seat time since Sunday. Looking at 4-10" more of snow tonight/tomorrow morning. So I'm going to get some more seat time in! can't wait!
   / What have you done to your Branson today? #282
Seat time is good.
Glad you're enjoying the wonders of winter tractoring.
   / What have you done to your Branson today? #283
I drifted. Unintentionally.
Was plowing when I was using the split brakes to turn tighter at the end of the run on the street carefully. Finishing the job, I was on my way back to my driveway when I tapped the brake on the inside wheel as I was making my turn. It drifted perfectly! My EVOC training kicked in and simply turned in the direction I wanted it to go and gassed it. In case you were wondering, it was all slick ice with no bare spots for the rubber to grab.
   / What have you done to your Branson today? #284
Maybe we should get together and do some tractor ice racing:thumbsup:
   / What have you done to your Branson today? #285
I got tired of never having the two most common tools with me: A shovel and a rake. There is no decent place to carry them on the Branson 4720ch, so I made a couple places out of some scrap 2" ABS pipe, some fabricated wooden support brackets and some nylon strapping. Probably an easier way, but this wasn't really that hard to make.
   / What have you done to your Branson today? #286
Cougsfan, that’s a first, seeing how it’s mounted! Wouldn’t it fly out while you are drifting?
Mine’s a 3520h with no cab. I’m curious if yours is the same type that can fit mine. How do you like it & how much do you reckon it cost?
   / What have you done to your Branson today? #287
Everything is easily removable for tractor drifting competition and ice racing:) Anyhow you might notice bungee cords wrapped around the tool business ends to hold them in place for the jumps and wheelies.
I had the ABS pipe laying around, but a 10' chunk of 2" ABS costs about $10. I used a 1 foot piece of 2x4 to make all 4 supports using my radial arm saw and belt sander. I should mention that the supports are notched to keep them from sliding sideways an the FEL rails. I painted the supports black to use up a partially full rattle can of spray paint. The 3/4 inch nylon belting and quick release plastic clips were left over from a motorcycle luggage project I did earlier, but can be bought on Amazon for under $10 (they cost a lot more at the hardware local store). The pipes are secured to the supports using wood screws. I think it would work on any FEL with minor modifications. I actually had the rake mounted last summer in the same pipe on a hack job for a mounting system and this is just a refinement. It worked just fine.
   / What have you done to your Branson today? #288
Cougfan,
Price of the cab, not the holders. I have boys to carry the tools ;-)
   / What have you done to your Branson today? #289
Yes, cabs are very good accessories for ice drifting.
I didn't get a quotes for a non-cabbed tractor vs a cabbed one. After owning cab-less tractors for years and have used the neighbors cabbed tractor on occasion, I knew I definitely wanted a cab. The cab makes using the tractor so much more pleasurable, especially in the heat of the summer and the dead of winter. There may be a few times that I find the cab a bit of an inconvenience, such as when spot spraying weeds, but I am not sorry I have it at all.
I am guessing it is about a $3 to $5 k upgrade. Maybe someone else has a better idea. I have no idea how easy it would be to retrofit a cab. or if a 3520 and 4720 cab are the same. I know the new 4720 cabs are slightly different (and slightly better) than mine. I would expect it to be quite difficult to retrofit a cab considering the air conditioning compressor and piping that would be required (maybe not required, but very desirable) to be added. Probably better off to trade the tractor in for a cabbed version (That isn't as bad as option as one might think. Tractor resale values are much better than cars).
   / What have you done to your Branson today? #290
Cool. Thanks! I don’t mind the summers, it’s the winter that is starting on me. I ain’t made of anti-freeze!
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
Highline Manufacturer BP661-100 (A57148)
Highline...
2020 DRAGON ESP...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
MASSAGE CHAIR (A58214)
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
