What have you done to your Branson today?
   / What have you done to your Branson today? #1,041
I changed my rear wheel spacing to the widest position to get more stability. It's about 78" from outside to outside of the tires. Only broke a 22mm socket and a 1/2x3/4 socket adaptor. I planned on using loctite on the lugs, but the tube was empty.
   / What have you done to your Branson today? #1,042
Personally I am glad your tube was empty. I do not like using anything on lug nuts.
   / What have you done to your Branson today? #1,043
I should have clarified I wanted to loctite (blue medium strength) the two parts of the wheels together and not the lugs holding the rim to the axle. I use anti seize on my truck lugs and where the wheel contacts the rotor or else they become very difficult to separate.
   / What have you done to your Branson today? #1,044
JM,
I do hope you were able to torque those bolts to spec? Aren't they like 450 ft/lbs?
I haven't had mine off, but I expect my 1" impact would get them off. However, torquing them back on would be a problem for me here. I'd have to farm that part out.
   / What have you done to your Branson today? #1,045
JM,
2ft long breaker bar if you weigh 225lbs ought to do it. I think that's correct check it online but it's pretty simple to get +- close enough like that.
   / What have you done to your Branson today? #1,046
I do like Dad taught me, tight as you can then half a turn. ;)
   / What have you done to your Branson today? #1,047
They didn't take that much torque to remove. I used a 30" breaker bar and it just needed a good push. The service manual shows the "Rim Disk Mounting Bolt" torque to be 122.4-151.2 lb-ft, which seems consistent with what it took to remove. Do you think this is wrong? I don't want the bolts loosing up. I have a 40" breaker bar that I can grunt on, but my torque wrench doesn't go upto 450 lb-ft. With the wheels far out, the nuts holding the rim pieces together can be easily accessed.
   / What have you done to your Branson today? #1,048
I went and found my operator's manual. It's different than the service manual. It says 188-224 lb-ft. I think I'll ask the dealer too.
   / What have you done to your Branson today? #1,049
Just get them them good'en tight with that long breaker bar then check them a few times while using her, they will be fine.
   / What have you done to your Branson today? #1,050
My dealer referred me to call Branson. The Brason service technical department said 122-151 lb-ft.
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
