Oil & Fuel What happened, why, & how big a job to fix?
   / What happened, why, & how big a job to fix? #11
I changed the hyd. filter on my BX2200 Kubota and when I removed the old filter a spring & a ball dropped out of the filter hole. I'm not a mechanic but I know that is not right. Hope someone knows what happened, why & how big a job to fix. Thanks in advance.
I have a BX2200 and have done maint on a couple of others. Starting with a 1939 Ford in 1960 I have changed oil in a lot of things (including my BX2200, a couple of B2150's, etc.) but I have yet to see a ball and spring fall out. I'd be reaching for the tranquilizer if I did ! I sure hope these other guys know what they are talking about. Experience counts.
   / What happened, why, & how big a job to fix? #12
To be that, and to find it there, it must be involved in pressure relief, fluid bypass, or prevent backflow/back pressure upstream from the filter. If you can't find a manual give Kubota a call for advice--I wouldn't run it until you figure it out.
Thanks for your reply. Thanks to daves1708 I received a link to a parts diagram & under control valve component parts it looks like my ball & spring are 050 & 060 in this diagram. I may have been wrong in thinking it came out of the hyd. filter hole as the drain plug was also off & the ball & spring where found in the drain pan. Could it find it's way there if it came loose & why would it come loose? You people on this list are #1, thanks!
UNUSED WOLVERINE PFA-113300G 48" PALLET FORKS (A57193)
UNUSED WOLVERINE...
ECHO CS-3410 GAS CHAINSAW (A57192)
ECHO CS-3410 GAS...
JOHN DEERE 5103 TRACTOR (A57192)
JOHN DEERE 5103...
UNUSED X-STAR 101" X 20' LOADING RAMP (A57192)
UNUSED X-STAR 101"...
2015 John Deere 5085E (A53317)
2015 John Deere...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
