what grease on PTO shaft?
/ what grease on PTO shaft? #1
44trxfun
western NY
MF GC2300
My mid-mount mower shaft is getting a bit dried out. What grease do you all use on your PTO shafts.
/ what grease on PTO shaft? #2
If you're just talking about the splines - I just grab a dob out of the grease gun. Other than sliding the shaft on or off the splines - there is no constant mechanical friction movement with the shaft during use (not like a bearing or some sliding movement) so as long as it stays on the shaft I'd think any reasonably heavy wheel grease or lube would work.
If you're talking about a u-joint then that could be a little more fussy.
/ what grease on PTO shaft? #3
I asked the same question after I cut the PTO shaft on my post hold digger to length. Of course I got that durned thing all covered with dirt and muck as I was cutting and testing it. So I wiped it clean with a bit of diesel and went to the parts store for some grease.
They said "any old grease" so I bought a little tub of wheel bearing grease. Slapped a handful on it and put it togather. Seems to work fine.
/ what grease on PTO shaft? #4
I agree with the others. if I need to generically grease something small, I use a squirt of grease from my grease gun ( which is loaded with NH 'blue' grease ). If i need a large amount of 'non-specific' grease, I dip my hand into my 5lbs tub of axle grease I have and rub it on whatever...
Soundguy
/ what grease on PTO shaft? #5
I think that most any grease is better then none at all, just don't over-do a good thing.
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
Club Car Golf Cart (A66285)
Club Car Golf Cart...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
INSPECTION (A65563)
INSPECTION (A65563)
Massey Ferguson 461 Tractor (A65579)
Massey Ferguson...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
