What exactly is the difference?
   / What exactly is the difference? #1
robertwhite
between a dash 1 (-1), dash 2 (-2) and a dash 3 (-3) on say a L3400?
Dealer told me it was just emissions although I surely don't believe it is strictly emissions.
** I am sure this has been discussed before, but I couldn't find it in a search.
   / What exactly is the difference? #2
On a L3400 it is strictly emmisions. And the good news if you can find a -1 or -2 they are at a lower dealer cost than current. I would buy it without hesitation.
But if you don't trust your dealer on a small detail like this you should consider going somewhere else were you are comfortable. But he did give you accurate info on a L3400.
Grand L's is a slightly bigger change in the newer dashes. Specifically on cab models as the latest dash allows for a Kubota BH to be installed. Also the headliner material is changed from plastic to cloth for a more upscale feel. The PTO engagement also goes to a push/pull switch. Again older stock means older (lower) cost and differences may not, to many consumers outweigh price advantage.UNLESS a BH is a future consideration.
Thanks.
Reason I didn't exactly believe him is that about half the questions I asked, he had no answer for and had to look up. And this place is Kubota only shop. :(
Heck, he had to ask another guy if the L3400 would pull a 5 ft bush hog without issues. (PTO HP puts it right at the 5hp per ft rule)
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
