What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets?
I have used a well placed fork to jack a car up for a tire change.
Note the emphasis on "well placed" fork. I know of a guy that did not get it well placed and tossed around $800 out the widow. Just mentioning for a friend. :(
   / What else do you do with forks besides lift pallets? #562
How tall is your barn door ?
(2) 10' x 10' doors.
I've been using a 40' shipping container for the past 20 years, which was a real hassle getting implements in and out of. The cabbed tractor that I got in 2016 wouldn't fit height wise, so barn dreaming / planning started then.
   / What else do you do with forks besides lift pallets? #564
Unloading a 1.3 ton milling machine from the delivery truck.
Pushed the limit of my machine; I had to shim the PRV to get extra pressure for this.
   / What else do you do with forks besides lift pallets? #565
Move firewood and hold it up to cut at a comfortable height and keep your chainsaw out of the dirt.
   / What else do you do with forks besides lift pallets? #566
I am trying firewood bags this winter. BX2230 holding up empty bag while filling from firewood processor. B26TLB moves the bags via the straps on top or the pallet below. Most of the wood is dead ash. Jon
Today was the first time in a year I used my forks for their actual purpose and removed a 350 lb toolbox on a pallet from my trailer.
No damage, easy to remove and an impossible task was made easy. I will always have forks.
   / What else do you do with forks besides lift pallets? #569
@groundcover I like that receiver hitch / hook on your fork extensions (y)
   / What else do you do with forks besides lift pallets? #570
Forks are also nice to lift up your mm mower deck so you can clean it and/or replace blades at standing height.
And do the same with a lawn tractor.
2012 Ford F-250 Pickup Truck, VIN # 1FT7W2B69CEB80936 (A57453)
2012 Ford F-250...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 INTERNATIONAL LF687 DAYCAB (A58214)
2017 INTERNATIONAL...
Hydraulic Thumb Clamp (A57149)
Hydraulic Thumb...
2025 GPS Trailers MDR2014K 24ft. 7 Ton T/A Dovetail Equipment Trailer (A56858)
2025 GPS Trailers...
