What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #162
I use mine to move the pump house to work on the well.
I wish my pump house was that small and I had a tractor to move the shed for a well driller to come in and pull the well. That was 20 yrs ago. 8' x 10' barn style wood shed, jacked up with hydraulic jacks and concrete blocks. Don't remember how the shed was moved away from the blocking. Sliding onto a trailer, maybe? Tractor with long forks and wide spread sure would have been easier. Jon
   / What else do you do with forks besides lift pallets? #163
I remove one fork and use the other to dig holes for new plantings in the yard and orchard. Also works really well to remove small plants or bring a rock to the top to be removed. Ken Sweet
   / What else do you do with forks besides lift pallets? #164
Shure makes life easy.
What? How did you not drop this with two loaders?
For the major part of the move, my neighbor's M8560 tractor with forks moved the shack. In the 2nd pic, his tractor is off camber and when he tried to lift the entire blind, it would start to lift one of his rear tires; and that's when I needed to use my tractor to lift that one edge of the shack.
It almost too big for his tractor and waaaaaaaaaayyyyyy too big for mine. The next two deer blinds will be smaller and far lighter.
   / What else do you do with forks besides lift pallets? #165
My neighbor used his to help me place our diesel generator in place.
Ralph
   / What else do you do with forks besides lift pallets? #166
Pretty much lift anything and everything!
   / What else do you do with forks besides lift pallets? #167
I use them to put the lumber rack and tool box on and off the pickup.
   / What else do you do with forks besides lift pallets? #168
Yes, Digging out stones.
Moving some old Fuel oil.
I ALWAYS use forks for breaking the bead on tires.
These particular forks are also hydraulically adjustable, allowing you some ability to pinch stumps and things adding yet another level of versatility.
   / What else do you do with forks besides lift pallets? #169
UTV lift!
   / What else do you do with forks besides lift pallets? #170
A TUNE UP!
Listening in on the neighbors!
2019 F150 (A56435)
2019 F150 (A56435)
2018 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
