What does this valve do on my 860?
   / What does this valve do on my 860? #1
buffaloman
Darrington
Massey Ferguson 1250, John Deere 300
I have a hydraulic valve of sorts under my seat. What does it do? hydraulic valve  of some sort.jpgtop hydaulic valve.jpg
I am thinking of attaching a one armed Ford FEL , what do i need to add for hydraulics???
   / What does this valve do on my 860? #2
That should be a one way hydraulic valve. The hydraulic line to the top pipe fitting. Pull the black knob to actuate and then it will work with your regular lift control. You'll see one on my NAA in this pic.
will the loader lift resonably quickly or will it take minutes to rise?
   / What does this valve do on my 860? #4
I had a front plow on mine, which worked pretty good, although, I put lighter hydro oil in, as it took a while to come back down, in the winter. A return line might be do-able. ??
   / What does this valve do on my 860? #5
lift rate will depend upon engine rpm and cyl volume.
   / What does this valve do on my 860? #6
The diverter valve will divert the power from the 3pt to the loader, snowplow or whatever you want. You will be able to use only one at a time but can switch back and forth with no problem. the 3pt lever is used to operate both. I have one i use on my 950 one arm loader with trip bucket and it works good.
kirk
   / What does this valve do on my 860? #7
the diverter uses the 3pt lift control to run a SA cyl, there would be no provision for a return line.
   / What does this valve do on my 860? #8
As I have been degreasing the tractor, I noticed a plug with a screw driver slot, behind the diverter valve assembly. I wondered is this might be for a return line? Or is it an adjustment for the draft control detent or something?
   / What does this valve do on my 860? #9
i've told you
NO RETURN LINE
   / What does this valve do on my 860? #10
i've told you:
single acting hyds don't utilize a return... they exhaust back thru the hose when the 3pt handle is dropped, and the system is unloading and exhausting... want faster drop.. lower engine rpms.
as for that slotted head.. under it are an oring, spring and ball. notice it is right over the draft control arm...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
2019 VOLVO L70H LOADER (A52706)
2019 VOLVO L70H...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
