3-Point Hitch What does this electrical connector go to?
   / What does this electrical connector go to? #1
Castle Rock, CO
2003 Kioti DK40
Hello,
Any idea what this electrical connector goes to? It is near the 3 point hitch on my DK40.
I just bought the 10 year old tractor used a month or so ago. Only had 336 hours on it!
Steven Chalmers
Colorado
   / What does this electrical connector go to? #2
It might be from a 7 pin trailer connector....
And, BTW, welcome to TBN. I'd call Michigan Iron/Equipment and ask them, send them a copy of you pic with tractor model # and serial #- they should be able to tell you for sure.
And let's see pics of your machine too!:thumbsup: Congrats on your purchase....
   / What does this electrical connector go to? #3
:welcome: The devil:devil: made me do this:D....since you have the picture of the female connector maybe the male connector. Trust me it's not the first time I've been called a :censored: go ahead. :mischievous: I had a KIOTI LK3054 when I lived in Idaho and never had any problems with it good luck with your new tractor.:thumbsup: +1 what Coyote machine suggested.
   / What does this electrical connector go to? #4
Not familiar with Kioti machines but a lot of Kubotas have leads for rear work lights...
Do you have any switches that don't do anything?...if so...you might try testing it with a volt meter and trying said switch...
   / What does this electrical connector go to? #5
The lead in the picture is for the 7-pin socket on the back of the tractor. There are Worklight Leads, but they are the bullet connectors.
Hope this helps
   / What does this electrical connector go to? #6
Hope this helps
I see three (power) pins with ground and switch legs...If you are a Kioti dealer (as per your profile) you didn't offer an opinion on what the connector is for...??
And I believe what most think is the "7th" pin is a snap lock for the connector??
   / What does this electrical connector go to? #7
I see three (power) pins with ground and switch legs...If you are a Kioti dealer (as per your profile) you didn't offer an opinion on what the connector is for...?? And I believe what most think is the "7th" pin is a snap lock for the connector??
What?
   / What does this electrical connector go to? #9
MIE IS a Kioti dealer, AND approved advertiser on TBN, as their profile shows. This is a FACT.:confused2:
The female pigtail plugs into it's male counterpart and provides wiring for a trailer connection to the tractor, as I stated/ suggested it might in post #2. The tractor also has a hot and ground for work light(s), not switched, but fused, for owner use.
   / What does this electrical connector go to? #10
I see six Brass points on the connecter too.
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2024 Hydraulic Trencher Skid Steer Attachment (A55851)
2024 Hydraulic...
2014 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK...
32 SWIVEL MINI EXCAVATOR BUCKET (A55745)
32 SWIVEL MINI...
2006 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A52707)
2006 CATERPILLAR...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
