3-Point Hitch What does this electrical connector go to?
   / What does this electrical connector go to? #1
Castle Rock, CO
2003 Kioti DK40
Hello,
Any idea what this electrical connector goes to? It is near the 3 point hitch on my DK40.
I just bought the 10 year old tractor used a month or so ago. Only had 336 hours on it!
Steven Chalmers
Colorado
   / What does this electrical connector go to? #2
It might be from a 7 pin trailer connector....
And, BTW, welcome to TBN. I'd call Michigan Iron/Equipment and ask them, send them a copy of you pic with tractor model # and serial #- they should be able to tell you for sure.
And let's see pics of your machine too!:thumbsup: Congrats on your purchase....
   / What does this electrical connector go to? #3
:welcome: The devil:devil: made me do this:D....since you have the picture of the female connector maybe the male connector. Trust me it's not the first time I've been called a :censored: go ahead. :mischievous: I had a KIOTI LK3054 when I lived in Idaho and never had any problems with it good luck with your new tractor.:thumbsup: +1 what Coyote machine suggested.
   / What does this electrical connector go to? #4
Not familiar with Kioti machines but a lot of Kubotas have leads for rear work lights...
Do you have any switches that don't do anything?...if so...you might try testing it with a volt meter and trying said switch...
   / What does this electrical connector go to? #5
The lead in the picture is for the 7-pin socket on the back of the tractor. There are Worklight Leads, but they are the bullet connectors.
Hope this helps
   / What does this electrical connector go to? #6
Hope this helps
I see three (power) pins with ground and switch legs...If you are a Kioti dealer (as per your profile) you didn't offer an opinion on what the connector is for...??
And I believe what most think is the "7th" pin is a snap lock for the connector??
   / What does this electrical connector go to? #7
I see three (power) pins with ground and switch legs...If you are a Kioti dealer (as per your profile) you didn't offer an opinion on what the connector is for...?? And I believe what most think is the "7th" pin is a snap lock for the connector??
What?
   / What does this electrical connector go to? #9
MIE IS a Kioti dealer, AND approved advertiser on TBN, as their profile shows. This is a FACT.:confused2:
The female pigtail plugs into it's male counterpart and provides wiring for a trailer connection to the tractor, as I stated/ suggested it might in post #2. The tractor also has a hot and ground for work light(s), not switched, but fused, for owner use.
   / What does this electrical connector go to? #10
I see six Brass points on the connecter too.
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
20 DISC SANDER/GRINDER (A55745)
20 DISC...
2006 INTERNATIONAL 9900I FLATTOP SLEEPER (A55745)
2006 INTERNATIONAL...
More info coming soon! (A55787)
More info coming...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
