What does a box blade actually do?
   / What does a box blade actually do? #11
Many thanks for the info.
So it looks like the principle use is to loosen up ground, and then re-distriubte it and re-grade it.
Follow on question. If you set the forks deep, could you also use a box blade as a sort of chisle plow? I'm talking for small 1 acre or less food plots here, not for 800 acres of corn.
Grouse
Hi grouse and welcome!
There are no "forks" , instead there ar anywhere from 4 to 10 scarifiers or teeth with hardened edges to break up and cut through rocks, roots, and other debris.
I think it could be good for what you suggest. Next spring, we will lightly drag the scarifiers (in conjunction with our Piranha Tooth Bar) to dig out the brush and weeds in the new food plot, then deeply drag to pull up any rocks or deep roots, and then lightly drag the backedge to smooth over the soils and regrade it.
   / What does a box blade actually do? #12
I would advise against pushing backwards....something is going to break if you are not real careful.
It's true. I am always really careful when doing it that way. It is just too convenient when grading to angle the blade way forward, then cut a path going forward, and spread it back out going backwards. No need to adjust the top link between the steps.
   / What does a box blade actually do? #13
A box blade is a lot like a grader blade except that the box blade has sides
I disagree.
There are SIGNIFICANT differences that a grader blade posses that a box blade can not replicate. Perhaps the most significant of those is the ability to rotate the blade and windrow material. in addition the grader blade can raise and lower the edges or side to side tilt. third a grader blade can change its angle of attack with the ground make it easier to cut hard materials or more vertical to grade and mix materials.
as stated a box blade is built primary built for cutting high spots and dragging material and filling in low spots or stock pilling the material.
   / What does a box blade actually do? #14
With the right operator a box blade can do finish landscaping. They are used a lot on big landscaping jobs and golf courses. With some practice you can do some very precision work. They allow you to carry material as well. If you can't afford a skid steer, some seat time with a box blade is the next best thing.
   / What does a box blade actually do? #15
I disagree.
I obviously have to agree with your first sentence that graders and box blades have different strengths.
But some of what follows is less clearly true.
True, windrowing is NOT done with boxblades, but rotating the blade to adjust the angle of attack to alter/enhance function between digging and smoothing ARE boxblade functions. Side to side tilting is accomplished by the 3-point linkage and we use this with our boxblade for ditching. Not all graders have adjustable blade heights.
My wife is better at grading the driveway than I am, and I would put her finished product using the combination of our FEL w/PTB and Gannon Earthcavator RO Boxblade up against anyone's without regard for implement used, just saying this to makwe the point that boxblades ARE good road/driveway grading tools in the right hands I.E., NOT MINE!
YMMV
Thomas
   / What does a box blade actually do? #16
Grouse
With plenty of tractor power, 4-WD, ideal soil moisture, and minimal rocks you can use a Box Blade to tear out subsurface roots. Not the same result as a Chisel Plow. Box Blade rippers are blunt, not tapered.
If the garden land has been previously broken a Disc Harrow may be the implement you need. I'm in Florida and in The South we tend to harrow rather than plow because of our mild winters.
If the garden land has NOT been previously broken hire someone to plow it with a Turning/Moldboard Plow in the fall. Winter freeze/thaw cylcles will break up resulting clods. Plow will cut subsurface roots 6-7" deep.
A PTO powered tiller would be the ideal implement for preparing not-too-rocky garden soil.
Picture shows my B3300SU, 33-hp, 1,900 pounds, with 630 pound Rollover Box Blade on 3-Pt., dragging out tenacious wild grape vine roots from sandy-loam/ NO ROCKS. (HST/LOW, engine grunting, R4 tires.)
   / What does a box blade actually do? #17
With plenty of tractor power, 4-WD, ideal soil moisture, and minimal rocks you can use a Box Blade to tear out subsurface roots. Not the same result as a Chisle Plow. Box Blade rippers are blunt.
Picture shows my B3300SU, 33-hp, 1,900 pounds, with 630 pound Rollover Box Blade on 3-Pt., dragging out wild grape vine roots from sandy-loam/ NO ROCKS.
That's one mean looking box blade and nice tractor :thumbsup:
   / What does a box blade actually do? #18
So what happens when they hit large rocks? Does the 4wd tractor spin tires or does the box scraper get damage? I am thinking of turning up our yard so I could plant grass vs. wild roses, rocks and weeds.
   / What does a box blade actually do? #19
I can't answer your question. I would NOT pull Rollover Box Blade rippers through rocky soil.
You could shallow dig your yard and grub out boulders with your Backhoe, then smooth the area and rake out some rocks and wild rose corms with a Ratchet Rake on your bucket.
If you have a large area to work a Turning Plow, used in the Fall, would be better, then pick up rocks in the Spring.
Pick up Wild Rose corms in the Fall, after plowing, so they do not break up and multiply.
   / What does a box blade actually do? #20
Depends. If it is too big the tractor comes to a stop. Football sized rocks tend to get pulled up and then, if I'm not paying attention, the box blade will end up bouncing up and over them. Smaller rocks usually just get drug along inside the box blade.
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2025 Mustang MP4800 2in Submersible Pump (A56860)
2025 Mustang...
2020 Utility Trailer (A60460)
2020 Utility...
Electric Man Lift (A57454)
Electric Man Lift...
Tractor Tires and Rims (A56860)
Tractor Tires and...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
