Oil & Fuel What do you use to fill your JD with Diesel?
   / What do you use to fill your JD with Diesel? #41
Well, I just spilled fuel all over the place filling my 2320 with a yellow can and that's it! I have a pump and now I'm going to make a set up to do it quick clean and right.
Do tractor supply houses sell around a 30 gallon tank I can put diesel in?
   / What do you use to fill your JD with Diesel? #42
Doesn't that just torque you off. I've done the same thing and
no matter how careful I am, there is always some spillage and/or
splatter. So, I, too, bought a AC-powered pump and hose from
Northern Tool. Haven't set it up yet.
Wish I had the cab model on my 3520 - the filler location is
in the left fender.
   / What do you use to fill your JD with Diesel? #43
mx125 said:
I won't forget to go with yellow or blue . . .as you say . .i already have enough gasoline powered things I would screw up.
I will look for a pump siphon . . .that sounds more elegant.
And that's good news on consumption. The JD specs had me thinking it would use 1.6g/h . .or 3.8hours at full throttle. I knew I'd have idling time to increase that . .but your estimate is twice or better than I thought. Great.
Thanks for the insights.
I found this wonderful siphon pump at my local Outdoor World in the boating department for under $10. It has this little one-way valve on one end and about 5ft of clear hose. You put the valve end in you fuel can and give it a bit of the "choke-the-chicken" manuever to start the siphoning. It can empty a five gal can in about a minute. You just pull the valve and out if you want to stop it sooner.
I set the can on the hood, but anywhere above tank level, in the range of the hose, will work.
   / What do you use to fill your JD with Diesel? #44
I am low budget if my tractor is loaded I stop by the Fuel Station and top off. If I fuel in the field I use two yellow 5 gal plastic cans with handle on top and side. The spout is self venting. I start pouring in and immediately set on tractor fender just balancing it until it’s about empty. I am cautious about dirt so I leave a about a pint in the bottom at all times. I always keep the top and spout clean, filled one of my cans yesterday and its still clean on the inside.
   / What do you use to fill your JD with Diesel? #45
I have two of the very same. I think mine came from WalMart @ ~$5 each.
Scott
   / What do you use to fill your JD with Diesel? #46
Yeah, those are the ones that Walmart used to sell (and is still available at my local TSC). They work ok. The style I got more recently at Walmart doesn't work so well.
   / What do you use to fill your JD with Diesel? #47
MrGraffix said:
We use the 30-gal gas caddy manufactured here in my home town by Handy Manufacturing.
1*Makes it nice when time for fuel cuz I can load/unload into back of truck with loader and eliminates having to lug heavy, leaky cans.
Not the cheapest alternative but definately more user friendly and cleaner!! I can't keep those little yellow seals/discs that keep the fuel from leaking out nozzle (or keep dirt & debris out) around for more than a month or two before I lose em! Pain in the a*# to boot. Check out the gas caddy here Handy Industries Online Store
If i had something like that I wouldn't fool with loading and unloading it into a truck with the loader.
I'd just have my fuel delivered.
   / What do you use to fill your JD with Diesel? #48
EdC said:
I use 2 5 gallon yellow diesel cans and then put a paint filter in the funnel. The 2320 sips fuel. I have spent several hours doing loader work and pulling brush and the tank will be more than half full.
I am looking into having a drum of farm diesel delivered. It is a Lot cheaper then the $3.00 or so per gallon for non dyed stuff. If I go that route I'll just get a crank pump.
Say you're 6 feet away from the tractor when cranking the pump then how can you tell when the tanks getting full with out running it over?
   / What do you use to fill your JD with Diesel? #49
mx125 said:
1*Attitive? Interesting. . .do you recommend a stabilizer due to the infrequent use . .or is there another additive that is importand for diesels?
2*-. Is there any downside to constant running with fuel stabilizers?
3*And i'll be sure to bring a funnel if I can't find a nice neat siphon solution.
1*powr service in the white bottle. 3 oz per 5 gal. 2*Never heard of any mentioned on any any of the tractor boards. 3* make sure it's a water seperating one.
   / What do you use to fill your JD with Diesel? #50
that's assuming you can get just 30 gallons delivered. as a previous poster mentioned, the minimum he can get delivered is 150 gal. here iirc, the last time i checked around it was 100 gal minimum delivery.
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2020 McLanahan 150 TPH USP Sand Plant (A55973)
2020 McLanahan 150...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
