What do you consider to be high hours?
   / What do you consider to be high hours? #11
... old semi trailer ... They were refrigerated trucks. The hour meter on one trailer read 9,000 and the other was 40,000.
1970's~80's ThermoKing refrigeration units? Very likely the same Yanmar 2 cylinder Diesel as in my (1980) YM240. This engine was also a standard for the tiny offshore Japanese fishing boats of that era where reliability is obviously critical. I'll never wear my tractor out in my lifetime. I have no idea if its three-digit hourmeter means 1,400, 2,400, 3,400 or whatever but it runs like new.
A smaller YM186D that I sold dyno tested exceeding new specs, at 30 years old. Hours unknown but had to be substantial, I rebuilt the steering box and discovered this was the second rebuild.
Your engines were probably still in decent running condition when those trailers were retired. Of course they may have been overhauled periodically, especially the 40,000 hour one. Replace the sleeves/pistons plus the usual and its essentially a new engine. I would like to hear what you do with them.
   / What do you consider to be high hours? #12
Contractors mower tractor jd6910 12800 hrs and mower/rake tractor jd6920 11000 hrs very high by contractor standards and quite high for most farmers to. My old 1964 mf 135 had done 11000 hours.
   / What do you consider to be high hours? #13
Around 420 for a lot of people.
   / What do you consider to be high hours? #14
If we (ourselves) work 40 hours a week or roughly 1800 hours a year and work 45 years thats give or take 81000 hours. And the the government still doesn't consider us wore out. So if it runs good looks ok thats all that matters. Just joking alittle guys :)
   / What do you consider to be high hours? #15
A forklift at work has 35 000 hours, it works shifts and rakes in close to 100 hrs a week. It is a 2007 model and still looks brand new.
   / What do you consider to be high hours? #16
Depends on the equipment year it was made.
   / What do you consider to be high hours? #17
Most farm tractor engines will go 10,000-20,000 hours and have many more thousands left in them when serviced properly. CUT tractors don't get the hours on them like larger farm tractors that might run 16 hours per day or more. Much of the degrading of CUTs is from setting unused and not many of them go 10K without something falling apart, if not the engine then the hydraulics or other parts. I would say 5000 hours on a CUT and I would be suspicious of what it has left in it.
Of course tractor engines are designed to be easily overhauled and then they are ready for another lifetime of work.
   / What do you consider to be high hours? #18
A real crude old timer in my town had a 1984 John Deere 410B 2wd backhoe that wore through two different hour meters. He was certain it had at least 25,000 hours on the original engine. He finally replaced it with a 4wd 410C, but the B still ran well when he sold it.
   / What do you consider to be high hours? #19
Hours is not a very good meter to use by it'self on evaluating a tractor. You can have a tractor with 6000 hours on it that was very well taken care of regular, and still has lots of life in it. Another tractor, abused by the op or hired help with only a thousand hours on it could be junk.
   / What do you consider to be high hours? #20
I made it 51,000 hours,, that was enough, I retired. :thumbsup:
(I did marry a wife with a similar career,, she retired at the same time,, so, combined, we put in 102,000 hours!)
I do not count the hours I work on my 40 acres,, that is play time,,
kinda like using a tractor to pull a float in a parade.
This tractor was delivered to the farmer January 2013, then returned to the dealer June 2016,, 1870 hours.
It was used for 42 months, or, what appears to be a little over an hour a day? (Dairy farm)
Supposedly, he has three of this type tractor, trades one every year.
EVERYONE considers it to have high hours,,,
On Thursday, I was the first one to ever activate the PTO,, it worked perfectly,,,
I LOVE these HIGH HOUR machines!! :thumbsup:
I might go back, and ask for the NEXT one he trades in,,,
2018 Ford F350 Flatbed (A55973)
2018 Ford F350...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
11 ft Shipping Container (A55973)
11 ft Shipping...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
