What do I really need?
   / What do I really need? #1
vallyfarm
Upstate N.Y.
Hi guys, I've been reading around here for some time now...a lot of different forums, and from everything I've gathered, the Yanmar is the tractor I'm looking for. What I need it for is to be small enough to clean out the goat pens with a loader, rototill approx. 5 acres of rowcrop garden, and ocasionally mabey pull a 1 bot. 3 pt. plow in well worked soil. Of course pulling wood wagons, etc. will come too. I've got plenty of larger tractors, but they ar just too clumbsy to wook in the tight areas of the strawberries and taters. I would get a 2wd. mod. because I've never needed anything more, and like to avoid as much "weak links" as possible. Sorry so long, but appreciate any feedback. Mike
   / What do I really need? #3
Would a 1610 be too large for you? I really couldn't see using a smaller model pull a single bottom plow. In my opinion, power shift is the only way to go.
   / What do I really need? #4
   / What do I really need? #5
I have A ym1700 and it want pull a bottom plow very good . I would go with the 2210 it is 26HP.
   / What do I really need? #6
   / What do I really need? #7
"I would get a 2wd. mod. because I've never needed anything more, and like to avoid as much "weak links" as possible.'
I would definitely go with a 4wd if you expect to pull a plow. As you said, you have never needed 4wd, but you have had larger tractors. Compact tractors are much better at pulling ground engaging implements with 4wd.
   / What do I really need? #8
   / What do I really need? #9
4 wd can come in handy with a full loader bucket also. I sometimes get stuck with a heavy load on soft deep gravel or mud. I have to dump the load and get un stuck. 4WD would be very handy then although maybe I would just dig all 4 tires in? I use my 2210 around the horse barn. It is sized ok for that. It is not as handy as a little skidsteer but it manuvers ok in tight quarters....Power shift is the way to go!!!!
   / What do I really need? #10
Year: 2018 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 225,027 Plate: Body Type: 4 (A51692)
Year: 2018 Make...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
Diamond (A53117)
Diamond (A53117)
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
