What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today?
429673771_7801251193220328_6648042813104244276_n.jpg Maybe I will start a new thread,, "Best Mods of the Month" :unsure:
I would have bought a Cab-Model, if I had known you can add AC this easily!!!
   / What did you do with your Chinese baby digger today? #483
No idea why the hour meter is not connected to the key switch…
Usually because the key switch does not have the connection for ignition ON, like a car has. So, the hour meter and headlight are wired directly to the battery thru the big red tee handle switch.
You need a starter switch like those on a riding mower.
   / What did you do with your Chinese baby digger today? #484
That drove me nuts too until I added a cooling fan. Now the sound of the fan running reminds me to throw the main disconnect.
I remember when I changed my switch so the hour meter worked on the key switch only. I noticed the original had the wires soldered to the bottom, and there were 2 unused solder points on the switch. I wondered then if maybe those were to be used for accessories when the key is on. I saved it and I planned on testing it to see. It was heavy and seemed like good quality. Definitely seemed better than the one I ordered from Amazon.
   / What did you do with your Chinese baby digger today? #486
Nice looking machine. Looks bigger than my 1-ton. I like the cylinder protection. Does it have hydraulic cooler and filter?
Cooler but no filter…well that know of:)
You may want to consider adding the filter. Most of the hydraulic components are pretty pricey. Some are hard to locate replacements for, and some are in places that only a 4 year old can get to..
   / What did you do with your Chinese baby digger today? #488
I took it off to do the bulk of the welding and paint. I'll post another picture when I get it mounted back up.
I finally got the crossbar finished and mounted up. I've attached a couple pictures of the finished product.
Nice work! Bet you feel better knowing you don't have a weak link anymore.
I wonder if those people who bent the frames, had any success fixing it?
   / What did you do with your Chinese baby digger today? #490
I'm just wondering if it would be a good idea to add some metal to protect the hydraulic lines or are they located high enough up that this isn't needed?
