What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #131
I decided on the ones I wanted and then had the dealer order them from tirechain.com so everything was included in the package when I financed it.
They are the V-BAR duo-grip, if I remember correctly.
Right on! Thanks!
   / What did you do to or on your Mahindra today? #132
I tried to figure why I have no cab heat in my Emax 25 HST. It is -27C where I live. I was unsuccessful so far.
   / What did you do to or on your Mahindra today? #133
Changing out the stupid OEM battery. Why do they put unsealed batteries in a tractor is beyond me. I just caught it in time so there's no acid damage, just post fuzz. The vibration had the acid drool out the vent caps. :thumbdown:
Cleaned all up and now looking for a nice Group 51 AGM.
Autozone near me didn't have a Group 51 but a Group 35 will fit. $182.
PepBoys has a Bosch AGM Group 51 for $142ish.
Good part is I have a short gig spreading out gravel for a garage pad so at least it's paid for. Decisions, decisions...
-R
   / What did you do to or on your Mahindra today? #134
MahindraBob: On my Mahindra 4510 underneath the tractor on the left side is a red lever. In the summer it should be turned one direction, in the winter 90 degrees differently. That permits hot radiator water to help heat the cab. I do not know if your tractor is similar but you could look. Just move it to open the valve. Also your interior cabin air filter could be clogged, a bad fuse could keep the blower from working. A variety of things.
   / What did you do to or on your Mahindra today? #135
Thanks yanmars. Turns out it was airlocked. I took cab roof off, pulled hoses off heater and manually filled. Then away it went
   / What did you do to or on your Mahindra today? #136
No seat time for me (yet). I picked up the Bosch AGM Battery from PepBoys late yesterday and had it charging all night. The final prep/clean of the battery area today and install. Using an old mouse pad underneath the battery to help with vibration and help to prevent over tightening.
Done!
I'm thinking of adding a 12v outlet by the auxiliary light switch.
-R
   / What did you do to or on your Mahindra today? #137
Got about ½ hour of seat time (in the cold-no cab) grading my drive and ¼ mile of access road, beaten up by logging trucks for other lots in our area that are being cleared.
   / What did you do to or on your Mahindra today? #138
Dig up my septic tank. Pumper coming in a few hours. Thankfully got some nice temperatures!
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
