What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,411
Dunno. Just noticed I was going through fuel faster the last couple of tanks, but attributed it to the tasks like mowing requiring PTO RPMs.
Tomorrow I have to play with 240AC for a while and wait for utility and inspector.
Suggest .. you might spray area with a degreaser like Simple Green pro HD, wash it off with pressure washer or hose, tighten clamps, etc., then add the paper towels to find leak .. if one still exists.
   / What did you do on or to your LS Tractor today? #1,412
Hit this milestone bush hogging yesterday.
My guess is the top hose, tighten the clamp.... Can you see any bubbling when it is running? It could be the seal around the cap, are the screws tight?
I can't see much of anything with the side panel on. I need to figure out how to get it off. I see the two bolts on the top, but are there any below or interlocking tabs that mean something else has to come off first?
   / What did you do on or to your LS Tractor today? #1,414
Yes, there are tabs going to the dash housing, and there are some down at the front bottom. The most difficult part is removing the 4 bolts holding the hood on(yes, the hood has to come off in order to take off the side panels) the side panel, headlights, and grill are all taken off as one unit. The whole process only takes about 10-15 minutes.
   / What did you do on or to your LS Tractor today? #1,416
Wait, what now? So, it's like a U? That would not impress me.
Maybe I can get a screwdriver to the clamp without doing that.
I cannot remember for sure, but I think there are 2 bolts on each side that mount the sides to the front.... I have a vague memory of taking off one side that way....
OK, so why would this happen in 2 years and 270 hours? Kimchee rubber?
attachment.php
   / What did you do on or to your LS Tractor today? #1,418
Tightened too tight by the looks of it, just bulged / squished the rubber until it cracked. At least it was a simple fix....
When I checked this morning, it was actively leaking within five minutes of the engine running at idle. Afterwards I ran it for ten minutes at idle and found no signs of leak. Then moved for a half hour and still dry.
>> How do I get to the canister fuel filter behind the headlights? I don't think my hands will go there.
>> What is the lever on the fuel filter? I thought it was a shutoff, but it's spring loaded. When I had the hose off, if I operated that lever fuel came out. Manual Primer?
>> There are about 50 screws holding the grille and headlight section to the side panel. If I ever have to disassemble that, those screws will NOT be going back in.
   / What did you do on or to your LS Tractor today? #1,420
That is why you have to take the whole assembly off / out of the way.
Yes, it is the manual primer / air release.
Yeah, the side panels can be a real B.... I put them back together with 3 or 4 per side, towards the very top and the bottom.... where I could get to them.
It never fell apart or cracked for about 100 hrs.... overkill?
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
1999 CLEMENT END DUMP (A58214)
1999 CLEMENT END...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
