What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #871
Hit 100.0 hours today
Loaded 21 batteries, 280 lbs each onto trailer with my pallet forks.
   / What did you do on or to your LS Tractor today? #872
Most recently we have used our LS to build a set of composting stalls trying to get a little more ready for next year and have a better place to keep the stuff that can be composted! The boys are glad the tractor was doing the heavy stuff!20191117_172339.jpg20191117_172329.jpg
   / What did you do on or to your LS Tractor today? #873
Today I had to palletize my 24kw diesel generator for shipment to Maui
I had it on dollies and had to get out of tractorshed. The backhoe prove handy
Then I had to get it transferred from dollies to the pallet. Forks to the rescue.
Got it in place
Bolted down, ready for truck to pick up in morning
   / What did you do on or to your LS Tractor today? #874
The big gen is loaded and gone. LS was maxed out.
Took a coordinated effort between tractor and lift gate.
Driver was initially surprised what he was picking up, but impressed with the LS.
I figure the palletized generator was likely about 2300lbs.
Size is primarily due to 2 factors.
1. the sound attenuating enclosure.
2. The 100 gal diesel tank. When I bought this I was still using 5 gal containers. Soon upgraded to the 125 gal storage which meant I’d get delivery for both, usually around 150+. Had already decided I’d replace this one when I went to 500 storage.
   / What did you do on or to your LS Tractor today? #875
Hopefully, my Dealer will show up with my new 48" Pallet Forks and to do a computer update (something about RPM and the Turbo).
Has anybody ever looked into having a locksmith rekey the ignition to something non standard?
   / What did you do on or to your LS Tractor today? #877
Probably cheaper to change the ignition. I’ve thought about breaking the bottom 1/4 off the key and sticking the broken piece in the bottom of the cylinder but I’m not sure if that would work or not.
I thought about that, but I'm not sure of the wiring and I'm still under warranty. I was thinking of getting a second OEM switch and keys so I could swap back to the factory if I needed to for some reason.
   / What did you do on or to your LS Tractor today? #879
Today I got a chance to play with the blue lady in the snow... Plowed 1/4 mile of the access road, then cleared out the driveway. We got over a foot of snow. Didn't remember to get a pic from the seat, but there she is "drying off" before I put her away. We're supposed to get some more snow again tomorrow night, so I will probably get some more wintertime fun in again!
   / What did you do on or to your LS Tractor today? #880
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2007 GALYEAN 130BBL VAC TRAILER (A58214)
2007 GALYEAN...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
