What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #411
I had some scratches on the center of the rear fender pan from turning the seat around. I found some self-stick rubber diamond plate (used for non-slip stair treads). Cuts to size really easy and provides a sealed protective cover. They sell them at WallyWorld, HF, and O'Reilly's auto parts. I also cut one in half lengthwise and put them on the front of the loader curl cylinders. I cut another in half an put it along the edge of the floor (where you step up) that isn't protected / covered by the foor mat. You could just cut a small square and put it where the hoses rubbed the paint off. It would take you longer to go get them than install. I don't have any pics of the ones I put on the floor or the cylinders, but I could take some tomorrow if you want to see.
I've got some of that on the BH floor and the rear fenders where the Lift Arms rub when I pull them up. Not sure I want that on the hood. Might try something similar.
Put these on a few days ago, but just got the pictures. Need a couple more bolts, but I ran out until I can get out to town.
   / What did you do on or to your LS Tractor today? #413
Yep, they will work great! One of the first mods I did to the tractor. I used 2 pieces of 1 1/2" angle on each foot, perpendicular to the tractor. Made a world of difference.
   / What did you do on or to your LS Tractor today? #414
Been real slack posting, but I have been busy the last few weeks. We're getting ready to have another carport brought in and put up. This one will be for the travel trailer to go under. The spot we're putting it, had a big pine tree. 75' tall, 32" across the stump. We got it cut down, then started limbing and using the tractor/chipper to take care of the limbs up to 4".
I did find out that even cut into 12' lengths, my XG3025 with it's 1600 lb lift capacity on the loader won't budge the bottom two pieces....LOL after some research, I've learned that white pine 32" diameter weighs 201 lb per ft, so that's right at 800 lb over lift capacity. I can roll them out of the way though. there's a local guy with a sawmill who says he wants them and can winch them onto his trailer, so he's supposedly coming to get them.
Then earlier this week, I had a guy come in with a stump grinder and take out that stump and a couple of others while he was here. First time watching that and I was IMPRESSED! I was going to rent one and do it myself, but he was less than the rental would have been, and done in a couple hours. Then I got to play on the tractor cleaning the mess up and building my mulch pile.
Then Wed, I had a load of asphalt millings brought in and I spread it where the camper is going. Yesterday, I serviced the lawnmower getting ready for spring, oil and filter changes, blades sharpened, grease job. Greased the tractor, blew out the air filter, checked all the fluids. I will say that if you have an air compressor, and DON'T have an air grease gun GET ONE! I just bought one of the cheap ones at HF and I am wondering why in the world I haven't had one of these already! Also, here's a heads up for you, if you break off a grease zerk, it's a 10 mm with the 1.0 pitch on the threads....and they are the devil to find....
finally, today I got around to doing something I have wanted to do ever since I got this thing and hooked up a 3 pt implement the first time. I took OFF the blamed PTO guard. With back and shoulder problems, dang near impossible for me to reach in there to hook/unhook. Yeah yeah, I know, it's a safety thing. Don't care, it had to come off.
I have tons of pics, but it's late, I'm worn out and me and the dog are ready for bed....actually he's already sleeping in my lap and me trying to type, LOL
   / What did you do on or to your LS Tractor today? #415
did important stuff today. Youngest daughters birthday, so we celebrated here at the house. Cooked a big meal, then got the tractor out, hooked up to the trailer I bought on FB market the other day for $80 and pulled the grand kids and the wife around the yard for a while. grand sons absolutely LOVED this!
   / What did you do on or to your LS Tractor today? #416
Ran the Torque App while putting some hay out for the cows just to see what it would do. The data here is cruising with a round bale on front.
Found this new little guy in the pasture as well.
   / What did you do on or to your LS Tractor today? #417
   / What did you do on or to your LS Tractor today? #419
Bought a new Woods land leveler yesterday. Now if it would quit raining and everything would unthaw and dry up some, I could get to work! Can’t wait to use it!
   / What did you do on or to your LS Tractor today? #420
You'll be very pleased with your grader. When I got my 84", I had an XR4046HC (in picture below) and it pulled it fine.
Now I've got an XR4155HC ...... even better!
Pictures when you put yours to work ..... it's the law.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
LOT: Flaring Tool Sets, Pipe Cutters, Brake Line Bender (A59076)
LOT: Flaring Tool...
