What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today?
Got a couple - three hours on the clock today. Moved some larger gravel to the muddy spot along side the road in front of my mailbox. Worked a couple of ditch areas that weren't draining well.
Then headed down a section of road to pick up the junk all the idiots toss out their windows. Got a loader bucket full in just about a half mile of road, both sides. I may try another section in the next few days. Won't last long, but it's a start. Some of this junk has been there for a year or more.
   / What did you do on or to your LS Tractor today? #392
Busy plowing 12" snow last 2 days. Plowed about 3 hrs. each day & 5 driveways each day.
It's not cold if you dress for it!!!!!!! :laughing:
Moved a bit more wood I had cut a few weeks back. Ground finally dried out enough to do that ... barely. Then did a bit more ditch work so the next batch of rain will hopefully drain better. Then tucked it back in the shed in advance of possible snow/ice tomorrow night.
   / What did you do on or to your LS Tractor today? #394
I started clean up with the LS on my project late today. With pic's as promised.
I am still finding uses for this EA Wicked Grapple. I call it the Wicked Twin. This is one pass with the Wicked Twin from the above picture.
Tomorrow I will hit it with the 3 pt power rake if the rain holds off.
   / What did you do on or to your LS Tractor today? #395
Here's a few pic's of the clean up from today starting with a pic of how the LS was set up on this project.
Almost done!
And finished!
   / What did you do on or to your LS Tractor today? #396
Looks real good! :thumbsup:
   / What did you do on or to your LS Tractor today? #397
Amazing result. I like it.
How much water can I run this thing through? 6" ? 8"? I figure I'm good as long as I keep the exhaust above water? I may need to pass through a distance of about 30-40' in the morning.
   / What did you do on or to your LS Tractor today? #399
I hope to never take mine swimming.
   / What did you do on or to your LS Tractor today? #400
It will run until it sucks water into the intake in an emergency. That being said, I don't know where the drive train vents are and they will certainly let water in when submerged.
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
Hyster H90FT 8,000lb Diesel Forklift (A55973)
Hyster H90FT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Bucket (A55973)
Bucket (A55973)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
