What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today?
Got a couple - three hours on the clock today. Moved some larger gravel to the muddy spot along side the road in front of my mailbox. Worked a couple of ditch areas that weren't draining well.
Then headed down a section of road to pick up the junk all the idiots toss out their windows. Got a loader bucket full in just about a half mile of road, both sides. I may try another section in the next few days. Won't last long, but it's a start. Some of this junk has been there for a year or more.
   / What did you do on or to your LS Tractor today? #392
Busy plowing 12" snow last 2 days. Plowed about 3 hrs. each day & 5 driveways each day.
It's not cold if you dress for it!!!!!!! :laughing:
Moved a bit more wood I had cut a few weeks back. Ground finally dried out enough to do that ... barely. Then did a bit more ditch work so the next batch of rain will hopefully drain better. Then tucked it back in the shed in advance of possible snow/ice tomorrow night.
   / What did you do on or to your LS Tractor today? #394
I started clean up with the LS on my project late today. With pic's as promised.
I am still finding uses for this EA Wicked Grapple. I call it the Wicked Twin. This is one pass with the Wicked Twin from the above picture.
Tomorrow I will hit it with the 3 pt power rake if the rain holds off.
   / What did you do on or to your LS Tractor today? #395
Here's a few pic's of the clean up from today starting with a pic of how the LS was set up on this project.
Almost done!
And finished!
   / What did you do on or to your LS Tractor today? #396
Looks real good! :thumbsup:
   / What did you do on or to your LS Tractor today? #397
Amazing result. I like it.
How much water can I run this thing through? 6" ? 8"? I figure I'm good as long as I keep the exhaust above water? I may need to pass through a distance of about 30-40' in the morning.
   / What did you do on or to your LS Tractor today? #399
I hope to never take mine swimming.
   / What did you do on or to your LS Tractor today? #400
It will run until it sucks water into the intake in an emergency. That being said, I don't know where the drive train vents are and they will certainly let water in when submerged.
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
2022 Lonestar 14ft. 5 Ton T/A Utility Trailer (A55973)
2022 Lonestar...
2014 Volkswagen Diesel Passat Sedan (A56859)
2014 Volkswagen...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
1994 Blue Bird School Bus (A55973)
1994 Blue Bird...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
