Eagle1
Epic Contributor
- Joined
- Jul 4, 2003
- Messages
- 26,455
- Location
- Viburnum, MO
- Tractor
- Kubota BX2200, LS XG3135H, Grasshopper and Yazoo Zturns
We had those, they were called scooter piesWagon wheels.
Two soft cookies with marshmallow in between and covered in chocolate.
They used to be twice as big hence the name wagon wheel.
I did not know.
I have a similar unit on my aerobic sewage disposal system. It has an aerator motor that has to run about 10 minutes each hour. The company that sells the system (Jet) wants $400 for the timer, but you can get them at McMaster for $60.A Tork 1101B mechanical timer from Home Depot. Simple swap for a unit that went bad. Probably should have bought a replacement motor unit, or just the entire module. Cost difference between the module and entire unit was negligible however. The unit switches my detached garage lights on-off.
I switched from the mechanical timers to digital years ago. The digital are far superior in ability to vary run times. I have 4 on my property. Only thing i have to do is remember to check lithium batteries every few years. Also, remembers time during power outage…no pesky resetting dial. Oh, and automatic DST.A Tork 1101B mechanical timer from Home Depot. Simple swap for a unit that went bad. Probably should have bought a replacement motor unit, or just the entire module. Cost difference between the module and entire unit was negligible however. The unit switches my detached garage lights on-off.
