What did you buy this week?
   / What did you buy this week? #2,081
It's safe to say you can add $1.50 to those prices for CA. I'm digging the EV for local run arounds.
   / What did you buy this week? #2,082
SOME INFO:
  • Affected Models: 2022-2023 Toyota Tundra and Lexus LX
  • Affected Engines: V35A twin-turbocharged 3.4-liter V6 engine
  • Production Period: Tundra: November 2, 2021, to February 13, 2023; Lexus LX: July 30, 2021, to November 25, 2022
  • Reason for Recall: Potential engine failure due to machining debris left in the engine
The 2024-2025 Toyota Tacoma has been experiencing a variety of issues, including transmission problems, electrical glitches, build quality concerns, and infotainment glitches. These issues have led to a lower-than-expected reliability rating from Consumer Reports
willy
   / What did you buy this week? #2,083
I bought 6 bags of driveway patch, just have to go pick them up.
With the heavy rains, comes the heavy damage to the asphalt.
   / What did you buy this week? #2,084
  • AUDI Q7 SOME PROBLEMS
  • Some Q7s, especially after a cold start, experience misfires. This can be due to a fault with the PCM software or the knock sensor.
    • The 3.0L engine in the 2017-2019 models is known for burning excess oil, which can lead to carbon buildup and potentially burned exhaust valves.
    • A faulty knock sensor can cause engine misfires and knocking sounds.
    • Some Q7s with the 3.0 TDI engine have experienced rattling noises and may require timing chain tensioner replacement.
      The air suspension, while providing a smooth ride, can be prone to failures, including sagging suspension, air compressor problems, and air spring failures.
      excessive noise, and water ingress can affect the electric steering rack.
    • A faulty residual pressure holding valve can lead to uneven ride height.
      The infotainment system can experience issues such as screens not turning on, random shutdowns, and connectivity problems.
    • Various sensors can trigger the check engine light.
      Some Q7s have been recalled for faulty crash sensors in the front doors.
      A defect in the steering system of certain models may cause loss of steering control.
Excessive brake wear can lead to frequent brake pad and rotor replacements.
    • : Coolant leaks, often from the expansion tank, are a common issue.
      Clogged sunroof drainage tubes can cause water leaks into the cabin.
    • Some Q7s with the Tiptronic transmission have experienced rough shifting, especially between 1st and 2nd gears.
    • Audi Q7s tend to have higher maintenance and repair costs than the industry average for luxury SUVs.
    • A Q7 may require a major repair during its first 10 years f service.
    • Regularly check for and address coolant leaks.
    • Be aware of potential issues with the 3.0L engine, especially in the 2017-2019 models, and monitor oil consumption.
    • willy
   / What did you buy this week? #2,085
    • willy
Mines a 2022. So most of the above is not an issue,
I'm sure I will find some though, it is an Audi.
   / What did you buy this week? #2,087
$25 fishing rack on FB marketplace. I'm seeing a cheap carryall here, it's 2'x4'.
   / What did you buy this week? #2,089
2016 28’ Claas Volto 870 tedder. Older, but low usage.
   / What did you buy this week? #2,090
Picked up a Harbor Freight McGraw 2hp 8 gal, compressor for $166. Decided to go with the 150 psi, oilless one, over the 135 psi oiled. I had the 2hp 8gal Black one, Pittsburgh or maybe Chicago Electric, but its acting up.
2014 PETERBILT 579 MID-ROOF SLEEPER (A58214)
2014 PETERBILT 579...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
