What did I stumble into?
   / What did I stumble into? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
A buddy mentioned finding a hydraulic motor in a house he was cleaning out. I mentioned I like hydraulic things for my tractor so he said "here" :thumbsup:
Can anyone help ID what he stumbled on?
ac
   / What did I stumble into? #2
I am not positive but I could send you my Address so that you could get rid of that terrible thing.. :)
Pretty sure it is the powerhead off of a Kanga Auger. Like a Toro Dingo type auger head. Quite an expensive chunk if that is what it is.
In all seriousness if you want to get rid of it cheap, my buddy just lost (literally, lent it out and the motor fell of the trailer) his, he bought a new one, but still has the mount plate etc.
I think you are right! It looks like it is from this:
[kanga files]
Ironically, I have a rock auger sitting on the premise...but no drive-method for it.
Any ideas what the specs on this thing might be?
ac
   / What did I stumble into? #4
Not really, but I think you could look up what a dingo, Kanga or similar produces, (I have not looked yet) and that would give you the spec I guess. I am thinking about 5 GPM but I may be way off.
Sounds like you have a drive, now make a bracket to hang it from your bucket and plumb it in with a diverter and you will be digging holes.
Already have a 3rd function for the grapple. 13gpm. I'd feel more comfortable if I knew the specs this thing was capable of. I am not sure what happens if 13 gpm are applied to something designed for 5 gpm. Maybe it just spins faster...maybe it make many little pieces of itself?
ac
   / What did I stumble into? #6
Looks mike a motor for a post hole digger to me.:thumbsup:
   / What did I stumble into? #7
Yeah, I found "Digga" from the label on it too. However, I can't seem to find any info about this particular item on their site. I am going to try emailing them.
ac
   / What did I stumble into? #9
ac
You don't need to worry about the flow. As long as the pressure is correct it will take only the flow it needs.
   / What did I stumble into? #10
A Dingo TX525 puts out 13.8gpm so your flow should be perfect.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
ALLISON TRANSMISSION (A53843)
ALLISON...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
