What did I do wrong?
/ What did I do wrong? #1
NDAWIND
Tampa, FL
John Deere 4520
Im new to this and want to learn what I did wrong to break both the sway links while I was bush hogging.
Tractor is a 4520 cab with imatch and MX6. I was backing into a ditch when it happend. I had both of the draft links in the float position. I thought I could back into a ditch safely and the cutter would move up and down as needed.
JD parts says 80 bucks or so for the replacements so this needs to be a one time learning expierence. Thanks in advance.
Darrin
/ What did I do wrong? #2
Obviously your top link does not swing or your not using chains so the mower can contour with the landscape therefore causing the mower to bind with the 3pt arm and bending yours as a consequence.
Thanks for the replies and I read the other thread. I thought everything was adjusted right. With the Imatch, it doesnt seem like adjusting the top link changes much, but like I said im new and sure have a lot to learn. Thanks again.
Darrin
/ What did I do wrong? #5
Darrin
Darrin,
I have a 4300 with an MX5 - no iMatch. When I need to back into a ditch, I raise the mower and then lower it after I am back as far as I need to be.
That said, the only thing that comes to mind that is likely to break the sway links is trying to turn (left or right) when the implement is against something that won't allow it to move.
/ What did I do wrong? #6
I don't do much backing into ditches but,,I have both my sway chains[side to side movement],adjust so there is a little play,,not much,but not tight,,have noticed on mine,,the side to side tightens up a little when lowered,,,I lower it almost to where wheel touches and make sure it can move back and forth maybe an inch or less,,,,also I don't use a regular top link when hogging,,use a length of chain,,it will still let you raise hog,[although not as much],,and let hog float over contour of the ground,,now I cut mostly tall grass,,and in grass you notice things like how well did it cut,,,brush you would be so apt to notice,or care,,,thingy
/ What did I do wrong? #7
If you are using solid stabilizer bars (anti-sway bars), you will place them into compression when backing up. An "overload" will cause them to "bend" and/or break.
Makes sense, thanks. I will leave the cutter raised from now on when backing and lower it when I get into the ditch. thanks much everyone.
Darrin
/ What did I do wrong? #9
My last rotary mower ( I believe it was a Howe I bought new in 1985) had an elongated top link attachment point that alowed the top link pin to move front to back about 3". I adjusted my top link so when I picked the mower up the rear of the mower was about 2" lower than the front and when I lowered the mower the top link floated so the mower would follow the contour of the field I was mowing.
/ What did I do wrong? #10
The JD LX series mowers has a flexible mast that allows for the rear of the mower to have some movement up and down even with a solid top-link.
But, I don't see how any height adjustment issues could break his horizontal sway links. I can see how backing against something imovable could push them both 'apart' but I honestly would have thought something on the mower would bend or break before the sway links. It also seems like the amount of straight back force needed to break the links would be obvious to the operator. If backing into something the tractor should bog, at least a little.
/ What did I do wrong? #11
I guess different mowers come with different top link connectors,,this kk I got came with a bent piece of steel that moved when you attached top link,,,but it didn't do much in the way of keeping rear wheel on the ground,,,tried it several ways,,,,than tried the chain,,been using it for 4 years like this,,works great. The only good that top link does for me on the mower is lets me raise it up,the chain does the same thing.
I know,,people will say it will keep your tractor from upsetting or flipping up,,,but,,,I cut on some steep hills that are not all that level,and the chain allows the mower rear wheel to remain on ground most of time,thus maybe carrying half the mowers weight,and the half thats futhest back,,so far,so good,now if you was cutting on much steeper hills than me,yep,that solid top link might be the best,,but I live in w.va.,and those hills I mow up are pretty steep,you wouldn't want to mow on much steeper hills anyways you'd do it.
As far as flipping up towards you if you'd hit something,,thats a possibilty,but it would hit rear of tractor before it got to me,,[plus,in my case,that ain't going to happen,I don't think],,
But if your connection allows yours to float thats even better,best of both worlds,,but if any body has trouble in this regard,try a chain. thingy
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
King Kutter II Tiller for sale.
King Kutter II...
John Deere Planter (A62613)
John Deere Planter...
2017 International 4300 Box Truck (A62613)
2017 International...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
