What did electric utility charge to run undergnd?
   / What did electric utility charge to run undergnd? #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
I'm looking to run 900' from the power pole on the highway to a box for distribution. 1 phase 240V for house, barn, garage, etc.
Current line is above ground & trees need trimming, leading to the underground alternative (right down the middle of a road so no tree cutting. Utility will pay for box & pad.
   / What did electric utility charge to run undergnd? #2
A few years ago I paid $5000 for an 800' run. That included all the dirt work, transformer, ($750), primary and secondary wire, conduit, backfill sand, meter, 200 amp panel box and breakers, a 100' feed to the house and the inspections. Above ground would have been $1500 cheaper. I did none of the work, I was out of town for a few weeks.
   / What did electric utility charge to run undergnd? #3
The electric company by me charges $7/foot.
   / What did electric utility charge to run undergnd? #4
I paid $4.00 per foot after the first 1000' of underground primary. Electric coop provided transformer between the house and shop so each has a good 200+ amp feed.
   / What did electric utility charge to run undergnd? #5
Many utilities charge on a pay back rate. So if you will heat with ele it can be free. In your case since you already have the service overhaed, I bet you'll PAY.
Patrick
Yep utility just called back my cost will be $2450.
Seems reasonable for a 300 yard run.
Thanks for all the info posters /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / What did electric utility charge to run undergnd? #7
The electric utility trenched the 600' run, supplied and buried the wire, installed a pad mounted transformer near the house and did it all for free about 6 years ago when we were building. The fact that at the time I was co-owner of a local HVAC company may have had a bearing on the freebie. /forums/images/graemlins/cool.gif
   / What did electric utility charge to run undergnd? #8
Geez,
You guys are lucky! SCE in Tulare County, CA wanted to charge me $24 a linear foot and another $24 per foot for trenching and conduit. That's from the nearest pull box which is about 1/2 mile down the road. My homesite is another 800' from the culdesac. That's $48 a foot for about 3500 feet! Do the math...It was a deal breaker when we were considering buying the property.
My nearest neighbor has solar completely off-grid with a generator back up system. He paid about $50,000 complete. I'm going totally solar-off grid and installing the same system. I'll be $125,000 ahead ... That buys a lot of batteries and propane and never an electric bill...ever.
   / What did electric utility charge to run undergnd? #9
Rewired this summer, replacing the overhead would be free, going underground was 50 cents a foot. Pad & trandformer were about $300.
--->Paul
   / What did electric utility charge to run undergnd? #10
I got the code requirements from the utility company and did everything myself except for the tie-in.......... /forums/images/graemlins/smirk.gif
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
Case Maxxum 140 (A50120)
Case Maxxum 140...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
UNUSED FUTURE SSJ430J WALK BESIDE JAW CRUSHER (A51247)
UNUSED FUTURE...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
