What did electric utility charge to run undergnd?
   / What did electric utility charge to run undergnd? #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
I'm looking to run 900' from the power pole on the highway to a box for distribution. 1 phase 240V for house, barn, garage, etc.
Current line is above ground & trees need trimming, leading to the underground alternative (right down the middle of a road so no tree cutting. Utility will pay for box & pad.
   / What did electric utility charge to run undergnd? #2
A few years ago I paid $5000 for an 800' run. That included all the dirt work, transformer, ($750), primary and secondary wire, conduit, backfill sand, meter, 200 amp panel box and breakers, a 100' feed to the house and the inspections. Above ground would have been $1500 cheaper. I did none of the work, I was out of town for a few weeks.
   / What did electric utility charge to run undergnd? #3
The electric company by me charges $7/foot.
   / What did electric utility charge to run undergnd? #4
I paid $4.00 per foot after the first 1000' of underground primary. Electric coop provided transformer between the house and shop so each has a good 200+ amp feed.
   / What did electric utility charge to run undergnd? #5
Many utilities charge on a pay back rate. So if you will heat with ele it can be free. In your case since you already have the service overhaed, I bet you'll PAY.
Patrick
Yep utility just called back my cost will be $2450.
Seems reasonable for a 300 yard run.
Thanks for all the info posters /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / What did electric utility charge to run undergnd? #7
The electric utility trenched the 600' run, supplied and buried the wire, installed a pad mounted transformer near the house and did it all for free about 6 years ago when we were building. The fact that at the time I was co-owner of a local HVAC company may have had a bearing on the freebie. /forums/images/graemlins/cool.gif
   / What did electric utility charge to run undergnd? #8
Geez,
You guys are lucky! SCE in Tulare County, CA wanted to charge me $24 a linear foot and another $24 per foot for trenching and conduit. That's from the nearest pull box which is about 1/2 mile down the road. My homesite is another 800' from the culdesac. That's $48 a foot for about 3500 feet! Do the math...It was a deal breaker when we were considering buying the property.
My nearest neighbor has solar completely off-grid with a generator back up system. He paid about $50,000 complete. I'm going totally solar-off grid and installing the same system. I'll be $125,000 ahead ... That buys a lot of batteries and propane and never an electric bill...ever.
   / What did electric utility charge to run undergnd? #9
Rewired this summer, replacing the overhead would be free, going underground was 50 cents a foot. Pad & trandformer were about $300.
--->Paul
   / What did electric utility charge to run undergnd? #10
I got the code requirements from the utility company and did everything myself except for the tie-in.......... /forums/images/graemlins/smirk.gif
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
