What could this mean? T4 75 horse 2023
   / What could this mean? T4 75 horse 2023 #11
The display has the little fuel pump icon with an exclamation mark, that's why I mentioned some sort of fuel related issue.
Unless that is the display I keep reading about, OP is that symbol always there beside the hours?
If not you have water in your fuel
no both gas symbol and exclamation mark both came on at same time.
   / What could this mean? T4 75 horse 2023 #13
Well there it is, it seems to think there is water in the fuel, if NH has standard symbols
   / What could this mean? T4 75 horse 2023 #14
Then as others have mentioned the exclamation symbol is telling you to check for issues and the water in fuel is telling you the issue.
So you need to drain the water catch in your primary fuel filter and clean the water sensor or possibly replace the filter/sensor.
   / What could this mean? T4 75 horse 2023 #15
22.9 hours means you're still under warranty. Let your dealer figure it out.
UNUSED FUTURE 13' 200 AMP JUMPER CABLES (A58376)
UNUSED FUTURE 13'...
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
7021 (A55851)
7021 (A55851)
