What could this mean? T4 75 horse 2023
   / What could this mean? T4 75 horse 2023 #11
The display has the little fuel pump icon with an exclamation mark, that's why I mentioned some sort of fuel related issue.
Unless that is the display I keep reading about, OP is that symbol always there beside the hours?
If not you have water in your fuel
no both gas symbol and exclamation mark both came on at same time.
   / What could this mean? T4 75 horse 2023 #13
Well there it is, it seems to think there is water in the fuel, if NH has standard symbols
   / What could this mean? T4 75 horse 2023 #14
Then as others have mentioned the exclamation symbol is telling you to check for issues and the water in fuel is telling you the issue.
So you need to drain the water catch in your primary fuel filter and clean the water sensor or possibly replace the filter/sensor.
   / What could this mean? T4 75 horse 2023 #15
22.9 hours means you're still under warranty. Let your dealer figure it out.
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
1453 (A57192)
1453 (A57192)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
