what cleaner/solution do you use in parts washer?
   / what cleaner/solution do you use in parts washer? #21
I learned that if your using mineral sprirts in your washer, to dump a couple of quarts of ATF in with the sprirts and it will save your hands from drying out and turning white. been doing it for years and it works.
   / what cleaner/solution do you use in parts washer? #22
I know this isn't what you guys are talking about but I have a heated ultrasonic parts washer. Dawn dish soap does a magnificent job! Some times I clean fuel injectors. I put them in a zip lock bag filled with Techron and put the bag in the ultrasonic cleaner. It always does a magnificent job. So good that I don't need to cycle the injectors when they are being cleaned.
Heat helps a lot for aqueous solutions.
That purple cleaner from castrol also does a great job.
   / what cleaner/solution do you use in parts washer? #23
I use Irsol (Varsol) in mine. Get a pair of the green Solvex gloves though. It can really dry out the skin (and not really that good to absorb either).
   / what cleaner/solution do you use in parts washer? #24
I have a couple ultra sonic cleaners.. used them for little parts.. etc..
soundguy
   / what cleaner/solution do you use in parts washer? #25
I used 50% real parts washer fluid. Flamable solvent based kind...not that water based crap they sell at most places. Expensive as all **** but well worth it.
i mix it with 50% kerosene (because 10gal of real stuff is WAY to expensive)
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
METAL STORAGE RACK (A52708)
METAL STORAGE RACK...
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
2017 VOLVO VNL64T300 TANDEM AXLE DAY CAB (A58018)
2017 VOLVO...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
1608 (A57192)
1608 (A57192)
