what cleaner/solution do you use in parts washer?
   / what cleaner/solution do you use in parts washer? #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
what type cleaners does everyone use in their parts washers?i was using straight simple green, but was wondering if there are better options.
   / what cleaner/solution do you use in parts washer? #2
I have used kerosene and have had good luck with it. I am not sure about the safety issue involved with using it.
I have used Simple Green and it has also worked well in many situations.
When I was a kid and worked on my vehicles I used gasoline but was never comfortable with using it. I didn't use a pump on the gas, just a heavy brush and manual labor.
If you aren't worrying about the paint on the parts a hot tank set up does a great job of removing grease and paint. The solution I used was a lye type solution. You can't put non ferrous metal in this type of solution or it will dissolve.
There are chemicals sold for commercial parts washers but I do not know what they are.
   / what cleaner/solution do you use in parts washer? #3
I use mineral spirits.. though in the past have used diesel and kerosene..
soundguy
   / what cleaner/solution do you use in parts washer? #4
Now JohnnyDark has raised the subject, i have a question too:
Will kerosene eat away rubber parts of a standard water pump ?
I want to make a parts cleaner from an oil drum, but i was warned by a friend: He made a heated one from an old laundry washer. 30 minutes after filling it, the rubbers were eaten away and the kerosene flowed out...
My band saw was missing a coolant pump, so i put a pond fountain pump in the coolant liquid reservoir, which works great.
If i buy another pond fountain to build a parts washer, will kerosene eat away that plastic jet pump ?
   / what cleaner/solution do you use in parts washer? #5
I used Varsol that I bought from the local Exxon fuel distributor, although since then they say they only have naptha which they claim is the same.
   / what cleaner/solution do you use in parts washer? #6
My buddy Tom a transmission guy use a mix of Mineral Spirit and Karol. He is a builder and all I have to say about working over a vat of solvent for your entire life is use a proper respirator. Nobody ever wants to hear it but inhaling solvent and soaking it through you skin will kill you :(
   / what cleaner/solution do you use in parts washer? #7
Thats true, from the days that i worked as a mechanic, i remember getting a white, dry cracked skin from the degreaser liquid... its just nasty stuff.
   / what cleaner/solution do you use in parts washer? #8
I learned very quickly that the Varsol would do thar really bad if you let it dry on your skin. I could work with my hands in it for long periods of time with no problem at all as long as I kept my hands wet with the Varsol, but as soon as I got my hands out of the Varsol, I dried them off quickly with a towel, and then washed them with the orange GoJo and water.
   / what cleaner/solution do you use in parts washer? #9
Pumps made to transfer water use different compound o-rings and gaskets than pumps made to transfer petroleum products. Just go to Harbor Freight and get a parts washer pump.
was thinking of going with mineral spirits. simple green is okay but you have to was it off, then blow off with an air hose. i know with a switch to a petro based cleaner gloves will become mandatory.
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
