what cleaner/solution do you use in parts washer?
   / what cleaner/solution do you use in parts washer? #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
what type cleaners does everyone use in their parts washers?i was using straight simple green, but was wondering if there are better options.
   / what cleaner/solution do you use in parts washer? #2
I have used kerosene and have had good luck with it. I am not sure about the safety issue involved with using it.
I have used Simple Green and it has also worked well in many situations.
When I was a kid and worked on my vehicles I used gasoline but was never comfortable with using it. I didn't use a pump on the gas, just a heavy brush and manual labor.
If you aren't worrying about the paint on the parts a hot tank set up does a great job of removing grease and paint. The solution I used was a lye type solution. You can't put non ferrous metal in this type of solution or it will dissolve.
There are chemicals sold for commercial parts washers but I do not know what they are.
   / what cleaner/solution do you use in parts washer? #3
I use mineral spirits.. though in the past have used diesel and kerosene..
soundguy
   / what cleaner/solution do you use in parts washer? #4
Now JohnnyDark has raised the subject, i have a question too:
Will kerosene eat away rubber parts of a standard water pump ?
I want to make a parts cleaner from an oil drum, but i was warned by a friend: He made a heated one from an old laundry washer. 30 minutes after filling it, the rubbers were eaten away and the kerosene flowed out...
My band saw was missing a coolant pump, so i put a pond fountain pump in the coolant liquid reservoir, which works great.
If i buy another pond fountain to build a parts washer, will kerosene eat away that plastic jet pump ?
   / what cleaner/solution do you use in parts washer? #5
I used Varsol that I bought from the local Exxon fuel distributor, although since then they say they only have naptha which they claim is the same.
   / what cleaner/solution do you use in parts washer? #6
My buddy Tom a transmission guy use a mix of Mineral Spirit and Karol. He is a builder and all I have to say about working over a vat of solvent for your entire life is use a proper respirator. Nobody ever wants to hear it but inhaling solvent and soaking it through you skin will kill you :(
   / what cleaner/solution do you use in parts washer? #7
Thats true, from the days that i worked as a mechanic, i remember getting a white, dry cracked skin from the degreaser liquid... its just nasty stuff.
   / what cleaner/solution do you use in parts washer? #8
I learned very quickly that the Varsol would do thar really bad if you let it dry on your skin. I could work with my hands in it for long periods of time with no problem at all as long as I kept my hands wet with the Varsol, but as soon as I got my hands out of the Varsol, I dried them off quickly with a towel, and then washed them with the orange GoJo and water.
   / what cleaner/solution do you use in parts washer? #9
Pumps made to transfer water use different compound o-rings and gaskets than pumps made to transfer petroleum products. Just go to Harbor Freight and get a parts washer pump.
was thinking of going with mineral spirits. simple green is okay but you have to was it off, then blow off with an air hose. i know with a switch to a petro based cleaner gloves will become mandatory.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
2006 JLG 660SJ SKYPOWER TELESCOPIC MANLIFT (A51246)
2006 JLG 660SJ...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
TUBELINE TL50LSV LOT IDENTIFIER 107 (A53084)
TUBELINE TL50LSV...
Gehl 55 Feed Mixer (A51573)
Gehl 55 Feed Mixer...
