What causes tractor rollovers?
   / What causes tractor rollovers? #101
I have a few spots on my property where I will not take the tractor - either vertical or horizontal. It might be OK but there is always the chance of a hidden hole or rock. It's just not worth finding out .............
Oh Yeah, and it can happen so fast even if you are going slow.
   / What causes tractor rollovers? #104
15 DEGREES slope and no more;
A tilt meter mounted on the center of the tractor hood or a slope meter taped on a piece of cardboard
and a no greater than 15 degree slope for sidehill mowing on a dry side hill is the one and only
thing that guaranty that you will wake up the next morning in one piece.
You have to stand at the bottom of the side hill and bring the slope meter cardboard to eye level and
then look to see what the slope is and if its above 15 degrees pass on mowing UNLESS you can mow up
and down with dry sod and someone pulling you up with a winch.
A ventrac will and can and will roll over even with dual tires so keep that in mind as it does happen.
   / What causes tractor rollovers? #105
No mention of COMMON SENSE????
Where I worked one time the foreman
said to the two new guys hope you have
some common sense and they both reached
into their pockets looking for change!!!!!!
willy
How to drive a blonde crazy put her in a
round building and tell her to sit in the corner
   / What causes tractor rollovers? #106
The main factor in tractor rollovers is tractor design above all else. Safety of cars has improved vastly over the last 50 years while tractor manufacturers just carry on turning out the same basic layout. You would want a safe car for your kids to drive but we still put up with unsafe tractors. Some tractors are safe on hills, but it is a small number.
   / What causes tractor rollovers? #107
I was using heavy equipment for paying my tuition and was driving a tractor when I was sent over to mow a steep hill near a school in the morning. Well, there was heavy dew so it was very wet and I slid down all the way to the bottom, over and over and I wonder how they managed to mow such a hill but I got it done. Well the next morning the assistant asked who had mowed that hill and when I raised my hand he went into a long "lesson" on the dangers of rollovers and how lucky I wasnt killed, and chewed out the one who sent me as he said you can never mow a hill when its wet or early morning, so my first lesson in tractoring..
Stupidity on the part of the operator.... simple answer.
   / What causes tractor rollovers? #108
Huh???
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
S/N: 1240824 (A55853)
2015 Audi A4 Sedan (A55758)
2015 Audi A4 Sedan...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
2013 Nissan Rouge SUV (A55758)
2013 Nissan Rouge...
