What causes a circle of dead lawn grass?
   / What causes a circle of dead lawn grass? #1
Fuddyduddy1952
Elite Member
john deere
I our front yard is a 20 foot diameter circle of dead grass, about 6" across. It may be hard to see in picture but you clearly see in foreground dead lawn and it's really almost a perfect circle.
I've had my soil tested by agricultural laboratory and it came back excellent except a little high in nitrogen. Rest of lawn (over an acre) is fine. Septic lines and tank is way away in back yard. No underground wires, phone, AC, pipes, etc.
Over the years any bare spot I lightly raked, seeded, then thin layer of potting soil, straw on top & it does great.
I've seeded this, doesn't help. Any idea what causes this? It's weird. (Aliens? ).
   / What causes a circle of dead lawn grass? #2
How long have you lived there?...it almost looks like there could have been an above ground pool there ?
   / What causes a circle of dead lawn grass? #3
I've seen dark green circles that are caused by fungus growth on abundant organic matter. In my area they're called fairy circles. If there was ever a tree in that spot I would guess fungus, but the fungus will grow outwards in a circle regardless.
Also could be a buried structure? Maybe the foundation of an old silo?
   / What causes a circle of dead lawn grass? #4
There are fairy rings that are fungus, but they are usually greener than the grass, not dead grass.
My 1st guess would be someone turned around while dripping/spilling weed killer.
When we 1st bought our 20 acres back around 1989, it was a farm field. All sand. There was an almost perfect circle about 30’ in diameter where nothing would grow except one type of weedy grass. Outside of the circle, any and all types of weeds and grasses would grow. Inside that circle, only 1. It took a good 5-6 years before anything else would grow there.
Our conclusion was that the farmer over-applied weed control while turning a circle or two.
   / What causes a circle of dead lawn grass? #5
   / What causes a circle of dead lawn grass? #6
Was there a farm on your property?
The circle looks slightly proud of the lawn.
My guess is a silo or maybe a circular pool/fountain foundation
   / What causes a circle of dead lawn grass? #7
At first glance I was going to say grubs too, but since it's almost a perfect circle, that kind of DQ's grubs. I'm leaning more in the camp of spilled weed killer, or a hydraulic leak while turning around.
How long has the circle been there? Just this year, 5 years, what?
If it's been there (and hasn't grown in size) for more than a year, I would get a probe and see if RJ isn't right with his "buried foundation" suggestion.
   / What causes a circle of dead lawn grass? #8
From my experience it is dollar spot or brown patch or something similar and you need to treat it with a fungicide. May take more than one treatment. It can be spread to other areas of your lawn by just mowing. I prefer liquid treatment to granular.
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
UNUSED KIVEL TRAILER MOVER ATTACHMENT (A54757)
UNUSED KIVEL...
UNUSED GRASSROOTS IMPLEMENT 6' SCRAPE BLADE (A54756)
UNUSED GRASSROOTS...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2002 PITTS 102" X 35' LOWBOY TRAILER (A51406)
2002 PITTS 102" X...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
