What can I put along the foundation of A pole buil
   / What can I put along the foundation of A pole buil #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
What can I put along the foundation of A pole building to prevent weeds from growing so that I don't have to weed whack after mowing?
   / What can I put along the foundation of A pole buil #3
I have the same problem. I was thinking of 2'x2' concrete pads around the perimeter. They sit low enough the side of the mower will pass right over without hitting em. I'd still have to occasionally trim or spray between to keep grass from starting.
   / What can I put along the foundation of A pole buil #4
   / What can I put along the foundation of A pole buil #5
Landscape cloth and small rock. It lets water pass through and acts as a weed barrier. The rock holds it down, covers it up and makes it look good.
Farwell
   / What can I put along the foundation of A pole buil #6
Farwell
   / What can I put along the foundation of A pole buil #7
I just use roundup on mine . After a few weeks your wind up with about 2" or 3" wide dirt barrier . Plenty of room for the mower .
   / What can I put along the foundation of A pole buil #8
   / What can I put along the foundation of A pole buil #9
when we first moved in about 7 years ago I had a problem with weeds in our new gravel drive so I used weedkiller. This old farmer across the road told me that rock salt would stop weeds, grass etc.. from germinating. I also have 18" gravel around my pole barn, no fabric. once you treat everything , with grass/weed killer pour on some salt , nothing will grow there.
   / What can I put along the foundation of A pole buil #10
2018 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
