Rear Blade What can a rear blade do for me that my box blade can't? Road and ditches mainly
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #1
MechanicalGuy
Platinum Member
Beautiful South
Kubota mx5200
So I have a Kubota MX5200 with the rear tires on the widest recommended setting and I spent quite a while trying to decide on a 72", 78" or 84" box blade. I'm so glad that I ended up with an 84". Any smaller would have been a mistake.
Now I'm making ditches and leveling/grading roads with my top and tilt hydraulic system, and it's working great, but it seems like the ditch part would be a little easier with a rear blade. I'm wondering if a 96" rear blade would be better than 84". I'm also wondering what capabilities a blade would give me. I really don't know what I'm missing. Can someone who knows the difference explain this to me?
So this stuff is obvious to me:
Scraper: can be angled to make more deep and pronounced ditch
Can be angled to bring dirt or gravel out of the ditch or the side of the road and towards the middle of the road for crowning
can be much more steeply angled than a box blade, typically, in at least 1 or even 2 planes.
Box blade: much better at filling in low spots because it carries a "box" of dirt or gravel
Better at digging down into the ground
has scarifiers, so roots can be torn up prior to making passes with the blade, this might be an issue on a scraper, if trying to dig into vegetation.
I also don't understand if a scraper can dig down into the ground, except for a little corner.
How much help will a scrap blade be to me? And how big should I get if so? It seems like an 8' might be fine, for the hangover outside of the tire line. It doesn't seem like it would be a liability because unlike a box blade, it won't anchor my tractor down if I get it oversized.
As you can see, I don't know much about scraper blades, or how they can be used. I've watched all the youtube videos that I can find, but I still don't quite understand what one might benefit me. Any help explaining them would be appreciated.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #2
A rear blade that can be tilted and angled will big a very good ditch and the can be adjusted for less tilt and angle to spread the spoils out evenly.
When used at an angle while grading on a road it can cut down wash boarding and distribute it.
Then if you spin the blade half way around the reverse curve when angled will distribute the gravel and actually compact it slightly.
I would want my blade to cover my tractor width when angled or more I have a 10 footer and an eleven footer at the farm.
10' wow. I have been looking at Everything Attachments and a locally made brand that only go out to 8'. I haven't seen anything but a light duty chicken house scraper that was 10'.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #4
Agree with all Lou said. Just to clarify one thing he mentioned or works best for me any way, when smoothing out was board road rotate the blade some so it is not staight like a box blade is. It will have the blade riding on more than one high or low area at the time and not as up and down as if straight. Hope made that plain. In other words rotate like you would to push dirt up the hill. You may run into needing weight on the front end if the blade turns the tractor, that is a big rudder when angled.
Too many people will think a rear blade is just like a box blade and say they are not worthless, they are made to grade and push the dirt to the side where a box blade is made to cut dirt and move it by pulling.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #5
Here's the 8050 with the 10 footer;
bought it old and used.
The deere is a 9 footer.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #6
To directly answer your question...the answer is "ANGLE"...!
To reverse the question...most rear blades don't have scarifer capabilities...
In my experience there is not much difference in what can be accomplished with either of the implements...based on experience etc..!
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #7
If you are going to get a rear blade for dirt work, get an 8 footer that weighs at least 100lbs per foot, or at least very close. Heavier is better. This means that you need to be looking at hydraulic actuated blades, or at least hydraulic actuated as an option to be looking at blades that are actually heavy enough to work well in about all circumstances-conditions.
You get a good heavy rear blade and learn how to use it to it's full capabilities, and your box blade usage will plummet.
You can roll some dirt with these, or take a light cut, all depends on what meets the requirements of the situation. ;)
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #8
The box blade is a poor at best ditch cutter. The angle and tilt ability of the rear blade makes it much better at this. Width wise I would want one that is wider than the rear wheel spacing width of the tractor when angled at its greatest angle. The only times my rear blade is set at the middle point (straight) is when knocking down a crown or stored (for max stability). When cutting ditches or smoothing out a driveway, it is always on an angle. If the driveway has ruts or potholes, then I want my BB and the scarifiers to bust up the base of these spots.
They are different implements designed for different purposes. Yes there are some overlaps, but some of the overlaps are done better by one or the other.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #9
Windrow the material to the side....
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #10
This ....
2008 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
